Vibration
I have a 1991 Camry, 3SFE, automatic, 212K miles, with a vibration that has been getting worse over the last few months.
The vibration is there all of the time, to the point where the car makes annoying rattling sounds in the interior, especially when accelerating.
A little background info about car:
-Two motor mounts were replaced a year ago, the front one by the radiator and the mount by the timing belt. The replacements were purchased from Autozone.
-New spark plugs were installed recently,
-Motor seems to run real smooth, no misfires or anything, and the transmission shifts pretty good
- Motor idle is a little over 600 RPM.
More info about the problem:
-Has the same vibration at idle and at driving speeds, seem to worsen when accelerating.
-No strange noises other than the suspension is a little noisy when going over a bump.
-There is a very noticeable difference when switching the car from drive or park into neutral. The vibration is greatly reduced when in neutral.
-The vibration does not seem to be related to speed, it is the same from park to highway speeds.
A few things that I may try:
-Sea Foam the intake and vacuum hoses. Has been a long time since I did this, and I can recall that it made a big difference in performance and motor vibration when I tried this before. Last time was in 2009.
-Ignition timing, could this possibly be off?
-Worse case, I end up changing out remaining motor and transmission mounts. If I go this route, what is the best brad to buy?
I am open to any comments or suggestions! Thanks!
Jeremy
