As Dr. J said, the power steering fluid should be Dexron ATF.
Are there any sounds (mooing, etc.) when you turn the wheel? With the engine running and the front end off the ground, have you gone from steering lock to steering lock multiple times to clear bubbles form the steering rack?
It sounds like there is something deeper going on, but hopefully it is something simple like this.
-Charlie
