mike40 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2011, 09:57 AM   #1 (permalink)
View mike40's Photo Gallery
Question mike40
Hello, new to forum, my 1991 Camry 4cyl radiator fan not coming on, fan works when i ran it direct to battery, got power to cooling fan switch that connects at thermostat housing, I grounded this wire but radiator fan still didn't come on and the relay continues clicking while the switch wire is grounded?????
mike40 is offline   Reply With Quote
Old 11-25-2011, 10:21 AM   #2 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
Welcome to TN.
Sounds like a wiring issue or a bad relay to me.
Zembonez is offline   Reply With Quote
Old 11-25-2011, 06:07 PM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Grounding the fan switch wire should turn the fans *off* not on. Unplugging the wire should have the fans run at all times (while the key is on).
I would guess a bad/sticky relay is your problem at this point.
-Charlie
Old 11-26-2011, 09:24 AM   #4 (permalink)
Mike40
Thanks guys, one more question, do the A/C relays have to be working also for radiator fan to work, I read on an old thread that if I pulled the radiator relay and tested the terminals that their should be power to terminal 1 and 4, I tested this with key on and only had power to terminal 1. Can I test relay before I buy new one???
Old 11-26-2011, 12:47 PM   #5 (permalink)
Gameroom cash: $303055
See if you have an identical relay in the car to some non-critical part and switch it temporarily for a test.
Mike
