Sealer on metal gasket? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2011, 11:55 AM   #1 (permalink)
View rickpthomas's Photo Gallery
Received the OEM gasket for the water manifold for the 3SFE motor. It is just a thin piece of punched metal to fit the gasket shape. Do I use any gasket seal with install? Seems like it would need something to seal the surfaces...
Thx,
Rick
rickpthomas is offline   Reply With Quote
Old 11-26-2011, 01:49 PM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
Do you mean the water pump? If so, the FSM says nothing about using sealant on the metal gasket.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 11-27-2011, 07:23 AM   #3 (permalink)
Thx for the reply...no, actually it's the water manifold (or that's what I thought it was called at least). See following pics...
Thoughts?
Thx!
Rick
Old 11-27-2011, 08:07 AM   #4 (permalink)
View Ted Striker's Photo Gallery
I've literally done hundreds of these. No you don't need it. Do make sure you replace both o rings.
Ted Striker is offline   Reply With Quote
Old 11-27-2011, 08:23 AM   #5 (permalink)
Thx...just to clarify though, which o-rings were you referring to? The o-rings on the water pump or the inlet pipe that goes between the water pump and the inlet manifold in my pictures?
'04 Sienna LE
'88 Camry LE
Old 11-27-2011, 11:36 AM   #6 (permalink)
Gameroom cash: $128800
View Sturdavj's Photo Gallery
Inlet pipe ()-rings
Sturdavj is offline   Reply With Quote
The Following User Says Thank You to Sturdavj For This Useful Post:
rickpthomas (11-27-2011)
Old 11-27-2011, 09:03 PM   #7 (permalink)
FSAE "Engine guy"
View Vlad1024's Photo Gallery
It's kind of like the crush washer on an oil pan. As you tighten the gasket deforms filling and imperfections on the surface making a seal.
08 tC mt
Smooth driving is comfortable and easy. It is also FAST(though not comfortable at speed). I don't care if you apex corners(everyone does) on a public road unless you suck at it(everyone). Hold a proper line or get out of my way.
Vlad1024 is offline   Reply With Quote
The Following User Says Thank You to Vlad1024 For This Useful Post:
Old 11-28-2011, 11:34 AM   #8 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
My car has a paper gasket in there; if your replacement gasket has no plastic coating and your sealing surfaces are having scratches/pits apply 1/8 inch (3 mm) wide bead of ultra-blue Permatex gasket sealant to the both sides of this gasket.
Plain piece of metal is only good on the new parts!
Doctor J is offline   Reply With Quote
