Main cap number order? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-05-2011, 04:26 PM   #1 (permalink)
Location: Houston, Texas, USA, North America, Northern Hemisphere, Earth, Galaxy, Universe, Vergo Supercluster
View oscaryu1's Photo Gallery
Hi guys, what is the numbering guide for the main caps? Took apart my old 3SFE and forgot to label
oscaryu1 is offline   Reply With Quote
Old 12-05-2011, 05:21 PM   #2 (permalink)
Gameroom cash: $163200
View Grego 92's Photo Gallery
Will these help you? I thought if you didn't number them then your kind of screwed, unless you kept them in some kind of order?
1990 Camry LE v6
1992 Pickup Dlx 4x4 4cyl.
2005 Nissan Frontier 4x4 Nismo v6
Grego 92 is offline   Reply With Quote
Old 12-05-2011, 07:31 PM   #3 (permalink)
I didn't keep them in order, but that's because each was numbered on the back (1-5, stamped on the back). I guess nobody knows
Old 12-05-2011, 07:46 PM   #4 (permalink)
Well, I would guess to say that they are like the first image at the top.....1-5 from front to rear (front being the left), but I believe your bearings have to be matched also.
BUT, have no fear, there are a few very knowledgeable guys who will likely come to your rescue in the morning. I've noticed they do their rounds in the morning to answer our F'ups! So don't lose hope yet, and keep checking back on your thread.
1990 Camry LE v6
Old 12-05-2011, 07:53 PM   #5 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
Have you checked the block? Possibly a corresponding number on it? Otherwise I have no help.
Zembonez is offline   Reply With Quote
Old 12-05-2011, 08:29 PM   #6 (permalink)
dem2757's Avatar
Gameroom cash: $274500
View dem2757's Photo Gallery
if you need to know the piston numbering so you can match the bearings, i think toyota numbers their engines from front to back
AKA passenger side to drivers side.
so the left of the engine, or the side that has the timing belt etc is No.1
At least on my V6 it is
Belts 1_3_5: flywheel
Belts 2_4_6: flywheel
dem2757 is offline   Reply With Quote
Old 12-06-2011, 01:07 AM   #7 (permalink)
I'll check the block, but no corresponding numbers that I remember of. Grego's picture depicts my problem - not sure which way it goes, 1-5 facing which direction
By the way - which directions do the pistons face on the 3SFE/GTE? Thanks!
Old 12-06-2011, 10:28 AM   #8 (permalink)
Look close, are there "^" triangle arrows imprinted on the caps? If so, I believe they should be pointing to the front (timing belt side, left, passenger, etc..), that would resolve which way they go and you have the numbering now also.
1990 Camry LE v6
Old 12-06-2011, 10:39 AM   #9 (permalink)
Gameroom cash: $285600
View '88 All-Trac's Photo Gallery
Are there any sorts of marks on the tops of the pistons? In all of my experience with Suzuki engines, the mark goes toward the front (in this case passenger) side of the engine.
'88 Camry All-Trac DLX 3SFE 5-speed manual
'91 Camry base-model 3SFE 5-speed manual
'92 Geo Tracker 4x4
'78 Dodge LeisureCraft
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
'88 All-Trac is offline   Reply With Quote
Old 12-06-2011, 09:38 PM   #10 (permalink)
'88 - There is a small circular indentation and a definite pin offset, that's all I know. I'll do some more research!
Grego - HEY! There are triangles! Three of them to be exact (on each main cap!), overlapping and pointing in the same direction. I'll check it, plastigage it, and get back to ya. THANKS!
Old 12-06-2011, 09:39 PM   #11 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
It's ALWAYS a good idea to take a lot of good pictures when disassembling an engine. It can save your butt in situations like this. In your case it is too late.
You may have to bolt up the mains and have the block line bored to solve this.
Old 12-06-2011, 11:11 PM   #12 (permalink)
Here is a picture of my 22RE showing the first three (the 3rd middle one isn't numbered)...you can see the same 3 triangles and they all point to toward the front.
1990 Camry LE v6
Old 12-06-2011, 11:14 PM   #13 (permalink)
Originally Posted by Zembonez View Post
It's ALWAYS a good idea to take a lot of good pictures when disassembling an engine. It can save your butt in situations like this......
Totally agree...I even take a video and speak what I'm viewing, noting, and seeing. Kind of like how you see those autopsy guys doing on tv...speaking into a tape recorder on what they are viewing and seeing.
1990 Camry LE v6
Old 12-12-2011, 06:38 PM   #14 (permalink)
87 Camry 3SFE
View Gazelle's Photo Gallery
2nd Generation Main Caps direction number.
I rebuilt my 3SFE this summer and yes there are arrows cast in the caps. Yes, they point toward the engine front and mine had the cylinder number stamped, you can see 5-4-3-2 in the picture.
The pistons have a dimple that face the front, IIRC the wrist pin is offset.
Gazelle is offline   Reply With Quote
