Compression Test - Reading Results - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2011, 07:49 PM   #1 (permalink)
View dbekk's Photo Gallery
There is a clean 1991 Camry for sale with 150K miles. A mechanic has performed a compression test and the range is 128-132. (I do not know if it was hot or cold when performed.)
Would these numbers give you any cause for concern? I think anything below 140 is cause for concern but is that true for even a car with this many miles?
dbekk is offline   Reply With Quote
Old 12-06-2011, 09:28 PM   #2 (permalink)
View Lee250's Photo Gallery
My 86 camry with 224,000 miles has about 160 psi compression. So I would think those numbers to be a little low but it would make a difference whether the engine was hot or cold. I think the Haynes manual say the limit is about 130 psi. But as long as it runs good I wouldn't worry about it.
1986 Camry 2.0 Not going to let it die currently 228,000 miles.
1999 Camry 2.2
1986 tercel wagon 2wd - sold
Lee250 is offline   Reply With Quote
Old 12-06-2011, 09:42 PM   #3 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
A lot depends on the gauge and whether the cylinders are dry or wet... hot or cold. What you mainly look for is compression that is fairly even (yours is) and well above 100 psi.
Zembonez is offline   Reply With Quote
Old 12-07-2011, 08:48 AM   #4 (permalink)
Found out the compression was done cold. Are the numbers going to go up or down? And if so, how much?
Old 12-07-2011, 12:05 PM   #5 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
There is no way to know. Take it for a test drive - if it runs well, you are probably fine. The even compression numbers are more important than the specific value, especially when done cold.
-Charlie
Old 12-07-2011, 01:53 PM   #6 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Doing this test with throttle closed will yield such figures (saw it on my car)
compression test must be done with throttle FULLY open, gas pump disconnected, ignition off and from remote starter switch
Doctor J is offline   Reply With Quote
