My speedometer works because it is mechanical (driven by cable) the wire I cut near the engine ecu was purple (but I cannot recall location from the top of my head; you need to see the computer pinout). Cutting wire at the speedometer cluster will set a code for transmission ECU and disable the cruise; the computer controlled transmission uses speedometer sensor as a back up, but if this sensor will be disconnected it will set an error code.
Cutting the wire near the engine ecu will put it into "rpm sensitive" not "speed sensitive" deceleration fuel cut/ fuel resume mode eliminating pulses from the sensor signal "noise" ( but the ECU on 91 model may behave differently)
sorry for confusing explanation
