Dome Courtesy Light Camry to ES 250 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2011, 04:31 PM   #1 (permalink)
Gameroom cash: $163200
View Grego 92's Photo Gallery
Don't know if this has been posted before but went looking for a new dome light. Mine was acting funny the switch was getting loose and ready to fall off, the toggle switch discolored to almost white, and plus I had already had to solder a piece of wire in it to keep it working (you can kind of see the black jury rigged wire inside of it).
Pulled one from a ES 250 and I think it's much better than the Camry's. Its bigger, seems brighter because of the bigger lense, the toggle switch is beefier, and it's the same color as the camry grey.
It's plug and play, all 4 screw holes line up perfectly, so a no brainer upgrade.
1990 Camry LE v6
1992 Pickup Dlx 4x4 4cyl.
2005 Nissan Frontier 4x4 Nismo v6
Grego 92 is offline   Reply With Quote
The Following 2 Users Say Thank You to Grego 92 For This Useful Post:
71Corolla (12-14-2011), silversrufer (01-08-2012)
Old 12-14-2011, 06:40 PM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
Sweet upgrade, I like it. Too bad the ES250 is such a rare car for me to find around here. You should buy the dome lights up from your local salvage yard and put them up for sale, I'd buy one.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 12-15-2011, 05:40 AM   #3 (permalink)
View echandler's Photo Gallery
^there are atleast 2 for sale on ebay now + the front seat light switch which would be an even cooler upgrade:
http://www.ebay.com/itm/LEXUS-ES250-...#ht_500wt_1081
echandler is offline   Reply With Quote
Old 12-15-2011, 09:08 AM   #4 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Thanks for the tip; what type of bulb does it use?
I'm going to upgrade mine (it is falling apart and did so on my late 79 Supra too)!
Doctor J is offline   Reply With Quote
Old 12-15-2011, 10:26 AM   #5 (permalink)
My Camry LE already has that type of front light, but if yours doesn't then you can grab one from another Camry that does also.
The bulb is the same, I have an LED bulb so just switched it over.
1990 Camry LE v6
Old 12-15-2011, 01:05 PM   #6 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
For those of you that want brighter interior lights (besides upgrading the bulbs), you can put a small bit of reflective aluminum tape behind the bulb to reflect more light into the car. Make sure it won't bridge the terminals on the bulb... I've done this on my WRX and Alltrac and it adds maybe 25-50% more light where you want it.
-Charlie
The Following User Says Thank You to white90dx For This Useful Post:
Doctor J (12-16-2011)
Old 12-16-2011, 06:42 PM   #7 (permalink)
View Kingdom934's Photo Gallery
I'd also like to add in
You will be able to use a E100 Corolla (1993 ~1997) Corolla dome light inside of a Gen1 (and I believe Gen2 since it looks the same). I only had to use 2 screws VS the 4 it had orginally.
I finally got LIGHT
The only thing is that the power connector will have to be flipped to fit. I did this and it works awesome without a hitch. No modding or cutting either
Basically I think anything that looks remotely similar for the mid 80's to the mid 90's should be okay.
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
