Replace shocks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2011, 05:44 PM   #1 (permalink)
View Esoto56's Photo Gallery
Replace shocks
My 89 camry groans and sqeeks when going over speed bumps but mostly only when its cold. i had a couple tire shops give me a quote on replacing the shocks and was kinda surpised at the cost, Les Schwab wants $700 and Firestone wants $1,200!!!! Is this an easy project to do at home? what all do i need as far as parts and tools are concerned. i do have buddies that are mechanicly inclined and willing to help.
Esoto56 is offline   Reply With Quote
Old 12-14-2011, 06:47 PM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
Removing the struts is not difficult at all. The more challenging aspect is compressing the springs to replace the struts and any other components that need to be renewed. FYI, if you are doing struts, go ahead and replace your control arm bushings and front/back sway bar bushings at the same time. Some control arm kits come with ball joints as well, which you should also replace as well.
Check out rockauto.com for suspension parts, they usually have really good prices.
edit - for tools, you need a basic 1/2" socket/ratchet set, same for 3/8" drive. A breaker bar with a cheater bar will probably be necessary to remove the large strut to hub/steering knuckle bolts. You will need a strut spring compressor if you plan on dismantling/replacing the strut assembly yourself. Or you can take it to a shop and have them do the job. Penetrating oil is your friend on a job like this.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 12-14-2011, 07:10 PM   #3 (permalink)
Gameroom cash: $285600
View '88 All-Trac's Photo Gallery
I recommend replacing the complete control arm as a single piece- you can buy them compete from Rock Auto for $60/ea. Rock Auto also carries struts for cheap. Do yourself a favor and buy some good spring compressors- they will last you forever. Be very careful working with compressed coils- prep the new struts as much as you can before removing your springs from the old struts. Buy yourself some strut goodies from o'reilly auto- they come with new bumpstops and boots. They will buy you some extra time with your new struts.
The job is not particularly hard but is time consuming.
'88 Camry All-Trac DLX 3SFE 5-speed manual
'91 Camry base-model 3SFE 5-speed manual
'92 Geo Tracker 4x4
'78 Dodge LeisureCraft
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
'88 All-Trac is offline   Reply With Quote
Old 12-14-2011, 07:30 PM   #4 (permalink)
71Corolla's Avatar
Yea Rockauto has the control arm kits that come with ball joints, get those. Replacing the control arms on the Gen2 Camry's is actually not that hard, easier than most cars, and I like the design itself.
Old 12-15-2011, 08:50 AM   #5 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Aftermarket control arms suck!
I got these arms w/ball joints @$60 each and they failed in 2 years or 10k miles. The ball joint boots were deteriorated as well.
I rather get stuff from the junkyard then from Internet sales
I am against the urethane bushings (they creak and make harsh ride) but ended up getting them from the junk yard with original 23 year old ball joints ($36 all)
As for the original problem asked in the post: get the silicone spray and inject it on the front sway bar U-bushings; if noise stops and bushings are good (not falling apart), apply the spray once a month
The bad struts are either making knocks or die silently (and the car will bounce like a boat)
Doctor J is offline   Reply With Quote
Old 12-15-2011, 11:30 AM   #6 (permalink)
71Corolla's Avatar
I put in FEQ (First Equipment Quality) units in 5-6 years ago and they have held up well. OES units are about double the price, if you can find them.
Old 12-15-2011, 01:52 PM   #7 (permalink)
thanks guys for all the help!
