Attempting Timing Belt Replacement...quick tips? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2011, 11:20 PM   #1 (permalink)
[Pro Snow Drift Hoonigan]
TurboATM's Avatar
View TurboATM's Photo Gallery
Ive read the Timing belt changing write up with some pictures tech article on the job, and think i can handle it. Timing is the one thing i never felt comfortable doing on my DSMs, there is no room for error on those...but the Camry is WAY more forgiving-i mess something up and i dont have bent valves and bruised pistons, it just doesnt run right.
Any quick tips that would help, that werent stated in the thread?
Also, being an All Trac, am I going to have issues trying to lift the motor up little bit to give me more room like the article shows?
Wish me luck!!!
1990 Camry All-Trac
1991 Eagle Talon TSi AWD
1997 Eagle Talon TSi
2010 Nissan Versa
TurboATM is offline   Reply With Quote
Old 12-14-2011, 11:40 PM   #2 (permalink)
Gameroom cash: $163200
View Grego 92's Photo Gallery
It's doable by a first timer, because I did it! ..... that post also has the other threads/articles I used.
1990 Camry LE v6
1992 Pickup Dlx 4x4 4cyl.
2005 Nissan Frontier 4x4 Nismo v6
Grego 92 is offline   Reply With Quote
Old 12-14-2011, 11:48 PM   #3 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
That guide is very good is covers pretty much everything. One trick I think works well to move the PS pump is to pinch/pull on the the belt before you remove it, I've done this a few times and it works great, instead of trying to find a location to pry the pump. You do need to support the front of the engine, and lift it up slightly to get the front mount off.
The horizontal mount bolt has a nut (not visible really) with a nub on it that hits the strut tower, that's what keeps it from turning. So when loosing the bolt, it might feel like you are twisting the bolt and breaking it, but it is just the nut rotating to the other side of the strut tower/stop.
Good luck.
Forgot to add, if you don't have a crank holder tool, or the tool you have is not strong enough, remove the starter (disconnect the battery first!) and jam a pry bar in there on the flex plate (I have a piece of a leaf spring that I use for this). If you do it right, the engine will defiantly not turn. With a breaker bar the crank pulley bolt will easily come off.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 12-15-2011, 09:01 AM   #4 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Be sure to include pictures with work in progress!
Doctor J is offline   Reply With Quote
Old 12-15-2011, 11:50 AM   #5 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
I did a timing belt on my Alltrac in the driveway in a couple hours. It shouldn't be difficult for you...
The Alltrac doesn't have the bottom 'center' mount, and there is plenty of play in the axles and AWD system to let you move the motor up and down. You can use the starter 'bump' trick to loosen the crank bolt if you don't have air tools. Remember that the motor is tipped back in the engine bay and that the crank alignment marks are vertical to the motor, not the car.
Oh, and consider doing the water pump, idler pulley and tensioner while you are in there... Maybe even the crank and cam seals.
-Charlie
Old 12-15-2011, 08:53 PM   #6 (permalink)
TurboATM's Avatar
I did it!!!
I wasnt able to do the "mark and count the teeth" trick, since my car had jumped timing...it wasnt as bad as i thought it would be, just alot of stupid crap that was pissing me off along the way...busted knuckles and cramped space was the hardest part, lol
i did change the pulley and waterpump...i ALMOST forgot to do the water pump...i got the belt on when my buddy mentioned i didnt swap it, lol. Thank god for him!
1990 Camry All-Trac
2010 Nissan Versa
Old 12-16-2011, 01:14 PM   #7 (permalink)
white90dx's Avatar
Nice!
How's the power now?
-Charlie
Old 12-16-2011, 05:30 PM   #8 (permalink)
TurboATM's Avatar
Originally Posted by white90dx View Post
Nice!
-Charlie
haha dude i prolly gained like 50hp...its actually quicker than i was expecting. Its no turbo car, but it gets up and goes.
...its no turbo car.....yet.
1990 Camry All-Trac
2010 Nissan Versa
Old 12-18-2011, 10:18 AM   #9 (permalink)
white90dx's Avatar
Let me know when you need guidance on that.
-Charlie
Old 12-18-2011, 10:21 AM   #10 (permalink)
TurboATM's Avatar
ha, ill take any info i can get man!
My DSM turbo guru has a t3 housing that will fit any mitsu turbo, and would make it face the same way as the 3sgte types do...hoping i can make that work with a 14b or soemthing
1990 Camry All-Trac
2010 Nissan Versa
