Originally Posted by Brandondavis
I was wondering because I'm doing a 3sgte swap in my camry in the near future, would the mr2 6 speed transmission be able to work with few modifications?Me and my friend have done alot of talking and I know some Mr2s came with the 6 speed transmission and I'm abviously going to be bulidling this 3sgte for power.I was just wondering if it would fit and work functionally considering it does connect to the block.And i believe having a 6 speed tranny would benifit when it comes to getting higher speeds.Just want some feed back on what people think and if anyone knows where I can locate one with the linkage and everything.
-Brandon
You and your friend are mistaken. There was never a 6-speed MR2... unless you are talking about a 2zz-ge swapped MR2-spyder or a mk1 MR2 supercharged with a hybrid transmission swap, neither of which count and won't work on the 3s-gte (bolt patterns and ability to hold the power).
Secondarily to all that, a 6-speed performance oriented transmission normally has the same 'range' of gearing that a 5-speed would have (first gear and top gear ratios similar). The 3s-gte has plenty of power over the RPM range, so you will appreciate shifting less than you would with some theoretical 6-speed - you lose around 0.5-1.0s for every shift...
-Charlie
