First, a stupid technical thing - What you are testing is an AFM (air flow meter) not a MAF (mass air flow) sensor. An AFM uses the big flapper door, a MAF uses a hot wire sensor (generally).
For the tests, here is what the wiring diagram says:
(Q) AIRFLOWMETER
1–2 : CLOSED WITH STARTER RUNNING MEASURING PLATE OPEN
5–6 : 200–600 Ω (MEASURING PLATE FULLY CLOSED) 20–1200 Ω (MEASURING PLATE FULLY OPEN)
5–4 : 200–400 Ω
5–7 :
10–20 KΩ (–20°C, –4°F)
4–7 KΩ (0°C, 32°F)
2–3 KΩ (20°C, 68°F)
0.9–1.3 KΩ (40°C, 104°F)
0.4–0.7 KΩ (60°C, 140°F)
It sounds like your's might be in spec... Verify that there are no 'dead spots' in the resistance between pins 5 and 6 (brown wire and yellow-green wire)
-Charlie
