Adding power windows and door locks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-18-2011, 05:41 PM   #1 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
Canada Adding power windows and door locks
I did some searching, but didn't come across anyone who had actually done this. I'm asking because I found a car at the salvage yard that has the same colour doors and door panels as my '87, but with power windows and locks. So I could grab all 4 doors, and of course the wiring harnesses, relays etc. But is this a plug and play scenario? Or will I have to start cutting and hacking into the existing harness? What about the wire loom for the back doors, my car doesn't have any wiring going into the back doors AFAIK, so I assume there is no hole in the door pillar, is this so?
Seems like a crazy project to be honest, but this is the first time I have seen the correct colour combination with the power stuff. Assuming some jackass doesn't butcher the car in the mean time, I'm really considering grabbing these parts. Thoughts?
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 12-18-2011, 05:57 PM   #2 (permalink)
Gameroom cash: $254267
View sarsman45's Photo Gallery
I've seen it happen, but from factory installs on my friends car years ago. AFAIK, you do need to do a bit of hacking into the harnesses but should be more easy going than to place pwr windows and doors on a model that has never had the option. What you really need is a wiring diagram of the car.
For the back doors, check by the hinges as there may be a plug blocking the wiring through the door and B pillars. If there is, you need to wire through the vanity plate on the B pillars. If not, well SOL.
'02 Toyota Tundra iForce V8 TRD AC THUNDER "FRACKING" GREY METALLIC 97000 miles
sarsman45 is offline   Reply With Quote
The Following User Says Thank You to sarsman45 For This Useful Post:
71Corolla (12-18-2011)
Old 12-18-2011, 06:02 PM   #3 (permalink)
71Corolla's Avatar
Looks like I am going to have to take another trip to the junk yard, there are so many Gen2 Camry's in there I can easily compare between cars with manual and power windows. I put in A/C a few years ago from scratch which was a real pain in the neck, I'm hoping this is at least a little bit easier.
Old 12-18-2011, 09:41 PM   #4 (permalink)
Gameroom cash: $128800
View Sturdavj's Photo Gallery
If you get the doors.....Take time to pull back the wiring loom and inspect for pinched, bent/broken wires particularly on the drivers side door. It’s a common weakness for the PW option.
I replaced/repaired six out of (I think?) nine wires on mine, “Now” my passengers side is beginning to act up.
Question 71’ does your car have the “power seat belts” they move when you sit down and close the door? These are also part of the door wire bundle, not sue if that makes a difference
Sturdavj is offline   Reply With Quote
The Following User Says Thank You to Sturdavj For This Useful Post:
Old 12-18-2011, 11:37 PM   #5 (permalink)
71Corolla's Avatar
My car does not have the automatic seatbelts, I don't think that was something they put in for the Canadian market. Later this weak I'll go back to the yard and try and figure out what needs to be done for this swap, although there is a chance the door panels and the like will be destroyed by people trying to get to door switches etc. Hate people that do that.
For the wiring, I fully expect that I will have to do a repair for the flexible sections. I've done it twice now, on my '87 and my '90 (which is out my hands now). It's a lot of work, I remove the plastic sheath and tape, and splice in wire from a non bendable section of a donor harness. Hate doing it, very tedious but it's the only way short of buying a new harness section, if even possible.
Old 12-19-2011, 04:40 AM   #6 (permalink)
I hate those people. Why do you even work on cars if you destroy everything to get to that 1 part you need? Good luck on grabbing those parts!
Old 12-19-2011, 09:51 AM   #7 (permalink)
dem2757's Avatar
Gameroom cash: $274500
View dem2757's Photo Gallery
fully expect the door switches to be torn out of the panels cause people think thats why their locks etc. dont work.
also, the faceplate of the switches is removable and you can change the color if need be. If you find the switches from one car and find the faceplate from anaother haha
dem2757 is offline   Reply With Quote
Old 12-19-2011, 03:19 PM   #8 (permalink)
View jonsey1886's Photo Gallery
Consider this a Christmas gift then.
Legally obtained by myself from toyota's subscription website for manuals. I'll try and find a link to that shortly, but IIRC it's $15-$20 for a day's access to the database.
jonsey1886 is offline   Reply With Quote
Old 12-19-2011, 05:05 PM   #9 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
You guys need to talk about this in PM if at all. No sharing of copyrighted material is allowed or endorsed on TN.
Zembonez is offline   Reply With Quote
The Following User Says Thank You to Zembonez For This Useful Post:
TrailDust (12-19-2011)
Old 12-19-2011, 05:49 PM   #10 (permalink)
My apologies. Won't happen again.
The Flying Deathtrap II My first Camry-
Gone 1/9/12 but not forgotten
1991 Camry 118k Miles
3sfe engine 150k
The Flying Deathtrap III-1990 Camry LE Wagon
153.5k Miles
2VZ-FE Engine
Old 12-19-2011, 06:52 PM   #11 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Its hard to tell from the diagrams what wires will be there or not on cars with/without options. Generally the wires are there though (on the body harness, at least).
People have been able to add power seats without any wiring, and my automatic Alltrac has the wiring for the clutch start switch, clutch cruise cancel switch, etc. for an auto->manual swap (I had to add a relay and move one other wire...).
Your best bet is to grab the door cards ASAP - the rest of the parts you can get from any power window Camry...
-Charlie
Old 12-19-2011, 07:43 PM   #12 (permalink)
Okay now I found the link I used about 3 years ago.
https://techinfo.toyota.com/techInfo...3/register.asp
If you need an FSM from 1990ish onwards for Toyota/Lexus vehicles go there. There is a $10 1 day subscription that will get you what you need.
I wish anyone who uses it luck as I remember it being a slight pain in the butt to grab everything I needed.
Taken from here:http://forum.ih8mud.com/80-series-te...wnloading.html
Good guide to rebuilding the FSM on your computer here:http://forum.ih8mud.com/80-series-te...ml#post5755095
3sfe engine 150k
153.5k Miles
2VZ-FE Engine
The Following 2 Users Say Thank You to jonsey1886 For This Useful Post:
71Corolla (12-20-2011), TrailDust (12-19-2011)
Old 12-19-2011, 08:46 PM   #13 (permalink)
71Corolla's Avatar
Going to try and make a trip to the yard down tomorrow. I don't want to buy the doors if I can't actually do this, I'll end up with 4 doors I don't need, or I'll have to return them. So I'll have to strip down a manual windowed car and compare the two, should be interesting.
Old 12-19-2011, 08:49 PM   #14 (permalink)
According to the FSM, it's the same door. If you have the FSM open up the section entitled "Body" and flip/scroll to page BO-4
3sfe engine 150k
153.5k Miles
2VZ-FE Engine
Old 12-20-2011, 05:36 PM   #15 (permalink)
71Corolla's Avatar
Just got back from Pick N Pull. Surprise surprise, someone messed up the drivers door panel. It was not completely destroyed, but they pulled on it and broke the backing in several places. Jerkoffs. The doors were not in that great a shape anyway, a couple of the doors has rust creeping in around the bottom. The paint was actually really good though. If I did get the doors I would have to do some rust repair for sure.
But here is what I found out. The door pillar on a manual windowed car does not have a hole for the grommet/wiring for the rear door, it would have to be drilled out. The wiring that goes to the back door is mostly separate from the main harness that goes to the back of the car, but not completely. So one would have pull/cut out the harness from the donor car, and splice in maybe 5-6 wires into the existing harness. The connector looks like it will plug into the fuse block though, at least on the left side kick panel. I didn't look at the right side, but it's probably the same deal, plus you will need whatever relays are a part of the locking circuit.
Not sure what else might be needed, but honestly to do this, it would be far easier to have a donor car instead of trying to get everything from the salvage yard. I could get a junker to strip, except very few are my colour combination, and fewer of those have power windows/locks. I've considered converting my interior to grey, mainly because the grey is extremely nice on the Gen2's, my '90 has the grey interior and after I cleaned it all up, it looked fantastic. A really nice grey, it has a nice hint of blue in it. So if I find a rust bucket with a grey interior I might grab it, although I don't look forward to stripping everything out, especially that dash sections that is a ton of work.
Bottom line, this is doable, but it is no plug and play job.
