Ball joint-to-knuckle bolt size - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2011, 09:20 PM   #1 (permalink)
Gameroom cash: $285600
View '88 All-Trac's Photo Gallery
Does anyone happen to know the diameter/thread pitch of the ball joint-to-knuckle bolts? My steering knuckle was slightly damaged when my ball joint failed and I don't have the time or money to rebuild a new knuckle... I just need to helicoil or maybe just tap the bolt holes and reinstall the knuckle...
'88 Camry All-Trac DLX 3SFE 5-speed manual
'91 Camry base-model 3SFE 5-speed manual
'92 Geo Tracker 4x4
'78 Dodge LeisureCraft
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
'88 All-Trac is offline   Reply With Quote
Old 12-20-2011, 11:48 AM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
IIRC, its M12x1.5 Easy way to check is take the other bolt thats presumably good to advance auto. They have a sizing board that you can thread the bolt into to confirm its size. I had this happen to the 89 I had where the threads stripped out of the knuckle upon installing a new ball joint. I purchased a Grade 8 1/2"x2" standard thread bolt. You can thread that bolt directly into the knuckle since the 1/2 inch is slightly larger than the M12 and it won't trash the threads on the new bolt. You will have to file out the inside of the ball joint a little to get it to fit nicely. It will grab inside the knuckle pretty well but to be safe here's part two. Buy a nut, flat washer and lock washer to match and lock the bolt onto the knuckle. There will be just enough of the bolt sticking out the bottom to add the nut and washers. Double check the size and measure before you go shopping. Its been over a year since I did this. I got the hardware from Home Depot for about $5. Good luck.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 12-21-2011, 10:41 AM   #3 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
It is M12x1.25
Drill it oversize and use "class 12" metric M12 standard pitch bolt with flanged nut of the equal strength on the other side. Torque to 90 foot-pounds
Doctor J is offline   Reply With Quote
Old 12-21-2011, 11:27 AM   #4 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Originally Posted by Doctor J View Post
It is M12x1.25
I'm gonna have to do this on the right front knuckle on my Alltrac.
-Charlie
Old 12-21-2011, 02:56 PM   #5 (permalink)
M12 seems awfully small... But I'll take your word for it. I spent all day trying to find a helicoil and couldn't, as sizing charts all placed it between 16 and 18mm... Leading me to believe it was a 17mm bolt, though when I tried a nut-board to find the size it came out to a 16mm thread size.
I'm not sure if the bolt was torn out or simply backed out- I did tighten it a second time at 300miles after the work was completed, but you never can be sure with the temperature fluctuations we get here...
'92 Geo Tracker 4x4
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
