Before you do anything, take the car into a reputable tire dealer for an inspection. If they find something wrong with the tread, replace the "set" of tires (either front or rear) to prevent any disasters. If they find nothing, ask what they charge to check the balance- some shops do this for free. For me, a rotation and balancing service was included when I purchased my lifetime alignment at Firestone. I do a lot of automotive work, so it worked out for me. If you do much work on your Camry, I recommend a lifetime alignment service.
If the cost isn't too bad, have them check the balance of your tires. That can cause a nasty wobble if it's out.
On your own, check your strut mounts (in the engine bay, left and right sides both) as well as all of your control arm bushings. Any worn out suspension piece in the front end can cause a wobble, if the wear is bad enough.
If all of that checks out, check your steering rack very thoroughly for leaks. If the rack is bad, get a replacement priced out. Find out what local reputable automotive repair shops will charge to replace it. If it's too expensive, you'll have to decide whether or not the car is worth it to you. If you don't want to pay but want to keep the car, decide if you want to tackle the project yourself. If you do, buy a Haynes (blah!) or a Chilton's (much higher quality) repair manual. People will say the original Toyota manuals are better, and they are... But they're written for people who already know their way around cars and understand more automotive lingo, if that makes any sense. See if you have the tools to complete the job. If you don't, see if you can rent them. Failing that, pick up a set of Husky brand tools (Home Depot) as they are both decent quality and not very expensive. They're Canadian-made, so they'll serve you well if you maintain them.
Don't know what else to say... But inspect everything as best you can, then take it in to a tire/alignment shop for a second inspection.
Good luck. Take care of your Camry and she'll take care of you for a long time to come.
'88 Camry All-Trac DLX 3SFE 5-speed manual
'91 Camry base-model 3SFE 5-speed manual
'92 Geo Tracker 4x4
'78 Dodge LeisureCraft
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
