HELP!! ECON blinking light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2011, 11:29 AM   #1 (permalink)
View HECINTEXAS's Photo Gallery
I recently purchased a 1987 Toyota camry with 242,500 miles. The a/c was working perfectly until yesterday. The ECON and A/c lights "blink" when I press on either of the buttons. The a/c is no longer cooling.
Any help would be greatly appreciated. Thanks
HECINTEXAS is offline   Reply With Quote
Old 12-28-2011, 12:49 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
That's the 'error' signal from the A/C computer. There is a problem in the A/C system somewhere.... It might be low refrigerant pressure, it might be a bad A/C clutch or some other problem.
Any signs before the A/C went out?
-Charlie
Old 12-28-2011, 01:19 PM   #3 (permalink)
Gameroom cash: $303055
It could be as simple as the A/C belt slipping. Check the belt tension and check the belt itself for glazing.
Mike
Old 12-28-2011, 04:58 PM   #4 (permalink)
WOW!! Thank you both for your quick response!! There was no previous indication of the a/c not cooling. I will check the belt first and more than likely have a mechanic check for leaks, clutch, or any other problem. Thank you once again for your guideance.
Is there anything else I can do before spending money to take it to a mechanic?
Old 12-31-2011, 04:58 PM   #5 (permalink)
Update
My a/c started to work again without having to do anything to it. Unfortunately, it only worked for a couple of days then it stopped working. The ECON light was blinking again. This morning it was not working, but just now I went to turn it on, and it is working again.
Do you guys feel it could be low on freon?
Old 12-31-2011, 05:34 PM   #6 (permalink)
white90dx's Avatar
It could still be the same things I mentioned in my first post above. See if you can find an A/C shop that does a free diagnosis and go from there.
-Charlie
The Following User Says Thank You to white90dx For This Useful Post:
HECINTEXAS (01-22-2012)
Old 01-22-2012, 12:14 PM   #7 (permalink)
Thank you!!
Just wanted to thank you for guiding me to find the problem with my a/c. I finally got around to taking my car to a mechanic and he replaced the a/c relay. He says I have to replace the "fuse box" where this relay goes because there seems to be a short there.
My a/c has not shut off since then. I will try to find the fuse box to replace in the future.
Thank you once again!!!
Old 01-22-2012, 01:34 PM   #8 (permalink)
Thanks for posting the solution.
Try the local salvage yards for the fuse box.
Mike
