oil dip stick tube - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2012, 04:18 PM   #1 (permalink)
View rpackin2's Photo Gallery
oil dip stick tube
how do i remove the oil dip stick tube in mr sons 91 camry four cylinder? is it pressed in, threaded?....something is stuck in it and the dip stick wont go back in
rpackin2 is offline   Reply With Quote
Old 01-02-2012, 04:38 PM   #2 (permalink)
Gameroom cash: $285600
View '88 All-Trac's Photo Gallery
Are you sure you aren't hitting the bend? Mine always go about halfway in and sort of stick. Does it go in if you sort of jiggle the stick up and down and turn it at the same time?
'88 Camry All-Trac DLX 3SFE 5-speed manual
'91 Camry base-model 3SFE 5-speed manual
'92 Geo Tracker 4x4
'78 Dodge LeisureCraft
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
'88 All-Trac is offline   Reply With Quote
Old 01-02-2012, 04:59 PM   #3 (permalink)
yes i am sure..its always been tricky to get back in but i can see something just beyond the bend...its a solid stop cant get past it...
Old 01-02-2012, 05:34 PM   #4 (permalink)
Okay... I don't know about all Camry 3SFEs, but with mine it has a little bracket secured to the block with a bolt and it then twists out of the mounting point.
Good luck! Let us know how it goes.
'92 Geo Tracker 4x4
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
Old 01-03-2012, 11:32 AM   #5 (permalink)
View dbekk's Photo Gallery
There is a small plastic part on the top of the dip stick that "seals" the opening. My plastic piece cracked off and this part may be what is lodged in your tube.
dbekk is offline   Reply With Quote
Old 01-11-2012, 03:05 PM   #6 (permalink)
87 Camry 3SFE
View Gazelle's Photo Gallery
When I rebuilt my 3sfe I stripped the block of everything but couldn't budge the dipstick tube, so left it rather than risk breaking.
Gazelle is offline   Reply With Quote
Old 01-11-2012, 03:09 PM   #7 (permalink)
87 Camry 3SFE
If the blockage is plastic try a flexible wire with a drill type end to grab it.
Bend the end into a short spiral and sharpen it.
Old 01-11-2012, 04:32 PM   #8 (permalink)
Gameroom cash: $128800
View Sturdavj's Photo Gallery
Has the bottom of the dip stick handle broken off and became lodged in the tube ?
I had this happen once on a Dodge... Was able to fish it back out... was a bitch.
good luck
Sturdavj is offline   Reply With Quote
Tags
91 camry, oil dip stick tube
