help with power windows wiring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2012, 05:28 PM   #1 (permalink)
skateordie's Avatar
View skateordie's Photo Gallery
my power windows started acting up a few months back...it would work when the door was open, it wouldnt when the door was closed..until it stopped working completely..
apparently, this is the culprit
all window switches on the master switch don't work, but the power locks button work, as well as the window lock button..
any ideas on how i can fix this?
skateordie is offline   Reply With Quote
Old 01-04-2012, 06:15 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Solder and some heat shrink tube?
You can also run a length of new wire through the door for those particular broken wires (so the hard solder joint isn't in the bending part of the wiring).
-Charlie
Old 01-04-2012, 06:22 PM   #3 (permalink)
dem2757's Avatar
Gameroom cash: $274500
View dem2757's Photo Gallery
http://s286.photobucket.com/albums/l...ness%20Repair/
this is how i did mine. both doors also.
dem2757 is offline   Reply With Quote
Old 01-04-2012, 08:24 PM   #4 (permalink)
skateordie's Avatar
sweet! thanks a lot for the walkthrough!
Old 01-05-2012, 11:46 AM   #5 (permalink)
white90dx's Avatar
I didn't pull the harness all the way out of the door. I just snaked what I could out in to the door body and worked on in just hanging out of the door.
And yes, that sheet metal is SHARP! I probably had at least 10 small cuts on my hands before I was done.
-Charlie
Old 01-05-2012, 12:28 PM   #6 (permalink)
Gameroom cash: $285600
View '88 All-Trac's Photo Gallery
I would see if I could find silicone-insulated wires in the proper colors- I only use silicone wire for my r/c applications as it is not so detrimentally affected by vibration and flexing... Should last you a good, long time.
'88 Camry All-Trac DLX 3SFE 5-speed manual
'91 Camry base-model 3SFE 5-speed manual
'92 Geo Tracker 4x4
'78 Dodge LeisureCraft
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
'88 All-Trac is offline   Reply With Quote
