Magnefine Transmission filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2012, 03:20 PM   #1 (permalink)
View itainthem's Photo Gallery
I have ordered a Magnefine off of ebay... While Im waitin for it to arrive.. Does anyone have experience installing one on a 3s-fe with auto trans.. do you know which line is return off of the cooler? I have 130k on mine and only plan on drain and refill.. no flush.. I had a bad experience with a flush on my last 2nd gen... It cost me a tranny.. so, this seems like the smart alternative to the flushing.. just a drain and refill and add a magnefine filter... 89LE wagon 3s-fe with auto and 130k.....
itainthem is offline   Reply With Quote
Old 01-08-2012, 06:19 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
For the return line, you have a 50/50 chance of finding out by just pulling one out and see. But you don't need to take it off for the drain/refill. Just undo the big hex nut on the trans pan, drain as much as you can then remove all the bolts around the pan, 16 bolts or so. Then you can get to the filter on the inside. Then refill fluid through the trans dipstick.
Old 01-13-2012, 06:30 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
After driving a while the cooler line should be the return line from the radiator. And verify it by using a segment clear PVC hose, something like $0.25/ft at Lowe's.
See also:
DIY Installing Magnefine filter on transmission oil cooler line (1mz-fe & 5s-fe)
The Following User Says Thank You to JohnGD For This Useful Post:
itainthem (01-14-2012)
Old 01-14-2012, 12:25 AM   #4 (permalink)
See also:
Thanks for that.. Of course it would be the cooler line after driving awhile...So simple a solution.. I just got the filter... Install tomorrow..
