Plastigage - use old or new bearings to measure? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2012, 11:47 AM   #1 (permalink)
88 All-Trac
empersons's Avatar
View empersons's Photo Gallery
I am starting to put the motor back together and am wondering about measuring oil clearance. Do I use the old bearings or new ones? Logic says the new one because the old would be worn, but still have no idea. If I measure the journals and they check out to spec, then would that conclude that new standard bearings would be fine?
Eric
1988 Camry All-Trac
Pictures
empersons is offline   Reply With Quote
Old 01-09-2012, 12:50 PM   #2 (permalink)
Gameroom cash: $163200
View Grego 92's Photo Gallery
Kind of confused reading your post, but I assume you removed the crank, then you bought new bearings to replace the old ones?
If you're originals were standard and you didn't have the journals grinded down then you would use new standard size rod/main bearings. You would use the green plastigauge on the new ones (and old ones if you aren't replacing all of them) to make sure you have the right clearance on all bearings rods/mains.
Basically whatever you're going to be running with is what you want to make sure is correct. Don't measure the hardware that you're going to throw away.
1990 Camry LE v6
1992 Pickup Dlx 4x4 4cyl.
2005 Nissan Frontier 4x4 Nismo v6
Grego 92 is offline   Reply With Quote
Old 01-09-2012, 12:55 PM   #3 (permalink)
Out of curiousity...what brand name bearings and piston rings are you using, and are you replacing the thrusts also? I used NPR rings and Taiho bearings on my 22RE, supposed to be the OEM manufacturers. They sure looked oem
1990 Camry LE v6
Old 01-09-2012, 12:57 PM   #4 (permalink)
88 All-Trac
empersons's Avatar
I bought DNJ bearings and thrusts. I believe the rings are DNJ or Rock.
Eric
1988 Camry All-Trac
Pictures
