Hey Camry lovers
This is my first post with my new(ish) Camry and I think I deserve a big idiot sticker so please bear with me and help me out
I had to toss my original Camry due to issues (see
here if you really wanna know) and got a nice 1990 Camry LE Station Wagon 2VZ-FE (V6) engine with a COMPLETE and FULL maintenance history.
Yippee. I noticed that the PO had a head R & R (removal & resurfacing) as well as all gaskets (head gasket set, tube seals, etc) replaced at 123k miles and he sold it to me at just over 152k. Timing belt and water pump were also replaced then too.
So I pulled the plugs, checked this that & the other before buying and noticed the following:
1.) No full antenna for the radio-it was snapped off about halfway and if anyone can give me any hints on where to find a power antenna (or other vehicles that I could pull one from a JY) I'd appreciate it
2.) Coolant leak-documented in records but listed as unknown it's amazing the simple things professional mechanics can miss as I replaced the upper rad hose the day I bought it and it seemed to fix it
3.) Vacuum leak-need to replace the busted BVSV (blue plastic vacuum hose thing probably broken when the head work was done) and then trace the hoses back to see if the leak still persists
4.) The driver's side automatic seat belt has been disabled because it would extend and then not retract (documented in records)
5.) No A/C-according to the records the compressor is locked and would need replacement (if anyone here knows a way around that please let me know)
Wound up buying it and then found out......guess what? It consumes oil (apparently quite a bit IMO) at about from full to below Low in 2 weeks or less. Which I don't quite get seeing as how I topped it off the day I bought it and then about halfway between L & F (on the dipstick) 4 days prior. Yes yes I checked the oil on a level/flat surface with the engine cold don't worry.
Also I deliver pizza so this vehicle will get a workout. So the other night while on delivery I noticed it running roughly and having just checked the oil before I headed off to work and finding it below L (this was Sunday night 22 Jan 2012) I got so peeved off that on the way back from my first delivery I bought a quart of oil and dumped the whole thing in
After that I got back to the restaurant and it wouldn't restart (turn over). Had to let it sit for a while and it wound up being just about 2 hours (due to the sheer volume of business) before I was able to go back out and try again, but it started right up. And yet now I notice it might be running ROUGHER than earlier?
Essentially what gives here?! Did I add too much oil? And why was it burning off that quickly to begin with if all the gasketry was replaced 30k miles ago? It hadn't seen anything like heavy use with the previous owner and he had been almost religious about fixing EVERYTHING the second he was told it needed to be.
