88 LE water leaking into trunk - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-15-2013, 02:44 AM   #1 (permalink)
View cadillacdude1975's Photo Gallery
when it rains, or the car goes through the car wash or even hand washing, the drivers rear quarter panel of the trunk fills with water.
i have the entry point narrowed down to 2 places. the next step is to get into the trunk with a flashlight and observe.
i think it is entering through the left (driver) outer tail light assembly. there is condensation all over the inside of the lense, so i have to see what light i have. amber on top or bottom? like i pay attention to those details LOL
i also want to change the weather stripping around the trunk for good measure. the factory seal is over 20 years old anyway. anyone got a link to where i can order that at a reasonable price?
thanks,
Rob
cadillacdude1975 is offline   Reply With Quote
Old 02-15-2013, 09:45 AM   #2 (permalink)
Senior TN Member
71Corolla's Avatar
Gameroom cash: $816750
View 71Corolla's Photo Gallery
Common sources of leaks are failing seam sealer along the edge of the trunk well, below the rubber seal. Also check the fuel filler area. Here's where I sealed mine up it cured the constant leaking problem.
Part number for the weatherstripping is 64461-32051. Contact Gary aka TOYOPARTSMAN for a price.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
The Following User Says Thank You to 71Corolla For This Useful Post:
cadillacdude1975 (02-16-2013)
Old 02-15-2013, 11:43 AM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $491075
If you remove the tail light on the leaking side, you will probably find a dirty/old/dry butyl rubber seal. You can probably find replacement butyl rubber 'rope' at the local auto parts store, like this:
http://www.oreillyauto.com/site/c/se...=ribbon+sealer
Otherwise, the suggestion for the trunk seal is the next step.
-Charlie
03 WRX Wagon 5spd
89 Camry Alltrac LE 3S-GTE 5spd
88 Camry Alltrac LE 5spd - blown motor
Previous: 90 Camry 3S-GTE, 90 Camry DX
Camry Parts FS
The Following User Says Thank You to white90dx For This Useful Post:
Old 02-15-2013, 12:18 PM   #4 (permalink)
thanks guys. i will pull the light later. i wish i had checked this post from my phone. i just left oreillys LOL
Old 02-15-2013, 01:11 PM   #5 (permalink)
Senior TN Member
Gameroom cash: $548300
View '88 All-Trac's Photo Gallery
My outer lights are both broken but, amazingly, don't leak.
My inner lights leak like sumbitches though. That might be something to check.
That seam seal is really bad about leaking, I've redone mine as well.
'88 Camry All-Trac DLX 5SFE 5-speed manual
'91 Camry base-model 3SFE 5-speed manual
'92 Geo Tracker 4x4
'78 Dodge LeisureCraft
'90 Ford Ranger 4x4
'88 All-Trac is offline   Reply With Quote
Old 02-20-2013, 08:22 PM   #6 (permalink)
still waiting on the darn stuff to show up in the mail. i wish it had gotten here today. its supposed to rain like mad sometime thursday and i will be in north carolina. blah.
Old 02-22-2013, 08:25 PM   #7 (permalink)
it arrived today. i can already tell a big difference in the way the trunk opens and shuts. its a lot tighter. im gonna get the water hose out tomorrow to be sure this problem is no more. i did see 2 spots that were slightly rusted on the lip, so maybe this was the problem.
Old 02-23-2013, 07:52 AM   #8 (permalink)
Toyota lover
Musikmann's Avatar
Gameroom cash: $101355
View Musikmann's Photo Gallery
Mine leaks too but I think it's a different problem. After the car sits out in the rain, and when I open the trunk, water drips from the drain holes in the truck deck lid on to the trunk floor. I suspect the seals around the tail light assemblies but I have done no investigation.
1991 LE V6 Toyota Camry Automatic (138,000+). Recently totaled (insurance decision) and now 95% repaired. Reconstructed title & registration.
Musikmann is offline   Reply With Quote
Old 02-23-2013, 02:19 PM   #9 (permalink)
something else came across my mind a few minutes ago at the car wash when cleaning out the trunk.
the motorized stereo antenna took a crap afte rshe got the car. i wasnt paying 60 bucks for a fancy up and down antenna. i bought one of the rubber ducky flexible ones and put it on the quarter deck. no difference in reception. i just dont have to worry about it snapping in a car wash.
i did notice today that when i tightened the base on the flex antenna, there is an ever so small gap that goes direct to where the water was pooling. a little silicone will stop that.
who is to say that is what was letting that massive amount of water in there, but it did need the weather seal.
Old 03-13-2013, 05:26 PM   #10 (permalink)
update: i found the leak. when it rained the other day, i was at the store. i thought to go check the trunk and the new weather seal is water tight. the water was running down the outer left channel by design, then down between the frame and the tail light assembly.
i then felt behind the carpet in the trunk, and bingo. entry point found. im gonna do it the easy way and use clear silicone to stop that little problem for now.
