Originally posted by Stevethecleric
btw: if you figure out how to correctly install in, PLEASE let me know, ive had one for 6 months, cant get it installed for the life of me!
The thread below has some instructions, but it applies to a 5S-FE. The basic hookup on a 3S-FE is the same, but the coil is wired differently.
MSD Ignition
Pictures of my MSD setup:
http://www.imagestation.com/album/?id=4289847013
Edit:
Instructions for a 3S-FE:
The instructions are pretty much the same as the ones for a 5S-FE, except its been rewritten for a 3S-FE.
Coil section below refers to a aftermarket coil (ie. MSD Blaster SS, etc..). If you use the stock coil (don't know why you would), ignore the coil section below and ask me for instructions.
MSD box
Big red wire: +12V
Big black wire: ground
Orange wire: Coil + (positive)
Black wire: Coil - (negative)
Both (orange and black) goto your new coil.
Red wire: hookup to the brown wire on ignitor (+12V switched (ignition)).
White wire: Not used. Tape off or heatshrink the connector on the end of this wire.
Tach adapter (MSD 8910-EIS)
Black wire: hookup to black wire on ignitor (tach signal).
Ignitor is located on the left side of the battery (see link to pics above).
Black plug with green and purple wire: Hook it up to the plug on the MSD box. You might have to use the extension harness that comes with the MSD depending on where you mount the tach adapter.
Coil
1. On the top of the distributor is a plug with 2 wires. Unplug this to disable the stock coil.
See link to pics above for which plug to pull.
2. Modify the distributor cap. Theres 2 spring loaded contacts on the inside of the distributor, remove one of them (which one you remove is up to you). Make sure you remove both the contact and spring.
Drill thru where the contact was. Use the screw that comes with the coil wire & post (MSD 84039 or MSD 8403) to determine the size of the hole that needs to be drilled.
The post needs to be modified, it won't sit straight onto the dist. cap as is. Modify as necessary, install, and seal around the outside of it with silicone.
3. Mount the coil (MSD Blaster SS, MSD Blaster 2/3, etc..) and hook it up.
Orange wire from MSD is coil + (positive)
Black wire from MSD is coil - (negative)
Hookup the coil wire (from MSD 84039 or MSD 8403) to coil and dist. cap.
P.S. Instructions have been stickied, so I don't have to type this out again.
http://www.toyotanation.com/forum/t17918.html
