1990 Camry thermostat slow to warm up, slow to go into overdrive - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2004, 01:20 PM   #1 (permalink)
View 38dean's Photo Gallery
I have a 1990 Camry, approx. 133k miles. The temperature gauge is slow to heat up and the overdrive will not kick in until the temperature gauge is past a certain point.
Not sure if I need to change the thermostat, already purchased one from Toyota, or look for another solution.
Thanks,
38dean
38dean is offline   Reply With Quote
Old 10-08-2004, 02:58 PM   #2 (permalink)
View RedRaven's Photo Gallery
Your Overdrive is fine. The Camry is designed to kick into overdrive once the engine reaches a certain temperature. As far as your thermostat, My camry takes about 10 minutes of running before the temperature hand will even show the slightest sign of movement and I just recently replaced mine.
RedRaven is offline   Reply With Quote
Old 10-09-2004, 02:11 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: 1990 Camry thermostat slow to warm up, slow to go into overdrive
Thats normal.
Theres a O/D water temp switch that screws into the thermostat housing.
The purpose of this switch is to enable o/d when the water temp is high enough. Or disable o/d when the water temp is to cold (engine not up to operating temp).
"Skoolin' the unlearned!"
