Welcome to the forum. The blue smoke is definitely a sign of oil consumption, but 1L per 1000km is quite bad. You're looking at major dough to fix something like that. I've been told that means bad valve seals or maybe gaskets need changing. There are engine oil additives that give a band-aid solution to the problem.
As for the clunking, the noise could be transmitted from the bottom, where all the linkages are. If it comes from the top, it probably means that your car is bottoming out and the strut cartrige is hitting up against the top. But the bump stops would probably stop that. I'd suggest getting those problems checked out if you have some dough to spare. Otherwise, it would be too big of a deal. Just have to keep adding oil.
I'm SUPER, thanks for asking;
All things considered I couldn't be better I must say.
I'm feeling SUPER, no, nothing bugs me;
Everything is SUPER when you're...
SUPERCHARGED!
