Originally Posted by backotruck
They say is runs from the firewall to the top of engine...I see 2 but one runs from engine to heater control valve to firewall and other is REALLy hidden???
The other hose that you say is hidden, is the outlet from the heater core to the engine.
Inlet hose to the valve runs into the back of the water neck that bolts onto the head.
And the outlet hose from the heater core runs into a metal pipe on the right side of the engine.
If you look on the front and right side of the block you'll see 2 metal pipes.
