On 2002-07-06 19:36, dark_pietro wrote:
which material would be the best to make it out of? Aluminum?
I would say aluminum is the best. Its light and it dissipates heat very well.
The problem is finding it in prebent shapes (180 degree u-bend).
And do I need to drain the system before I start to work on it.
What are you gonna drain? Air?
Just remove all the stock crap (intake piping, airbox, tubes, and resonator).
One thing you'll have to do is enlarge the hole underneath the fuse box. It helps if you remove the battery so that you can get to it.
_________________
88 LE
Team C-Spec
Powered By 3S-FTE
"Boost 0wNz j00!"
Theres no replacement for positive manifold pressure
<font size=-1>[ This Message was edited by: 88 LE on 2002-07-08 09:17 ]</font>
