Superpro Poly-Gen 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-16-2005, 09:58 AM   #1 (permalink)
Zfreeman's Avatar
View Zfreeman's Photo Gallery
European Union Superpro Poly-Gen 2
Hi guys,
Got the whiteline rear swaybar recently, and figured I might as well
replace some of the bushings while I'm under there too!
Couple of questions?
1-I've heard that Poly bushes tend to create a lot more noise and vibration
than the stock ones, any truth in that? (Spent a lot of money on suspension
already, don't want any annoying noises going on)
2-If I do decide to get the poly bushes, is there a kit with all the bushes? (I'm
having a bit of trouble figuring out all the part no's)
Zfreeman
1991 Camry SV21 3S-FE AUTO (JPN)
1988 Camry SV21 3S-FE MAN (JPN)
Zfreeman is offline   Reply With Quote
Old 02-16-2005, 10:31 AM   #2 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $110550
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
didn't your Whiteline RSB come with pollyurathane bushings? ...if you bought it new it should have.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 02-16-2005, 11:04 AM   #3 (permalink)
Zfreeman's Avatar
European Union
I neglected to say it's the other bushings I'm asking about, control arm, trailing arm, etc
My RSB did come with poly bushings and grease.
From the Superpro Catalogue:
Camry
SV20, 21, 22 Sedan & Wagon
5/87 - 1/1993
Front Control Arm Lower - Inner Bush SPF0511K 1 SV20 , SV21, ZV21 4cyl & V6 vehicles 4B,2T
Front Sway Bar Mount To Chassis Bush SPF0329-24K 1 PS & DS standard caster setting 2B
Front Sway Bar Mount To Chassis Bush SPF0329-24AK 1 PS increased DS standard caster 2B
Front Sway Bar Mount To Chassis Bush SPF0329-24BK 1 PS increase / DS increase or decrease caster 2B
Front Sway Bar Mount To Chassis Bush SPF0329-26K 1 PS & DS standard caster setting 2B
Front Sway Bar Mount To Chassis Bush SPF0329-26AK 1 PS increased DS standard caster 2B
Front Sway Bar Mount To Chassis Bush SPF0329-26BK 1 PS increase / DS increase or decrease caster 2B
Front Sway Bar Mount To Chassis Bush SPF0329-27K 1 PS & DS standard caster setting 2B
Front Sway Bar Mount To Chassis Bush SPF0329-27AK 1 PS increased DS standard caster 2B
Front Sway Bar Mount To Chassis Bush SPF0329-27BK 1 PS increase / DS increase or decrease caster 2B
Front Sway Bar To Lower Control Arm Bush SPF0321K 1 4B,2T
Rear Control Arm - Inner Bush SPF1221K 1 Rear arms, Rod type arms 2B,2T
Rear Control Arm - Outer Bush SPF1220K 1 Rear arms, Rod type arms 2B,2T
Rear Sway Bar Mount To Chassis Bush SPF0462-_ _K 1 Measure bar diameter 14,16mm available 2B
Rear Trailing Arm - Bush Kit SPF0823K 1 8B,4T
PS=Passenger Side
DS=Drivers Side
B=Bushings
T=Tubes
Old 02-16-2005, 01:30 PM   #4 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
Camry
5/87 - 1/1993
PS=Passenger Side
DS=Drivers Side
B=Bushings
T=Tubes
What color are the bushings because I think that makes a difference. I have heard that the black ones are the quietest of them all and then red ones are have the most noise. I think you will be fine though as long as you grease them and keep them greased up. Also you might want to consider getting at least poly bushings on your sway bar because what is the point in having a nice thick bar and crappy bushings.
Hotwheelharmer is offline   Reply With Quote
Old 02-16-2005, 01:38 PM   #5 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
where do you get these poly bushings from i can't seem to find them
Old 02-16-2005, 04:17 PM   #6 (permalink)
Zfreeman's Avatar
The bushings are made by Superpro , an OZ company. As far as I know Whiteline sell them in Oz, I think CT Motorsport might sell them in US, as they
sell Whiteline stuff. GlobalPerformanceParts sell them in US too. As well as a few companies in Europe. Not hard to find these bushings, in my experience..
Like I said.....
Old 02-16-2005, 05:29 PM   #7 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Bushings should not ADD noise, but they will transmit more noise from the road and suspension. If you don't want a performance car (and the associated noise and roughness) don't do it. If the bushings get low on grease, they will start squeaking/creaking - that's when you know its time to re-grease them.
That being said, the bushings are about as stiff as the stock rubber on my WRX, so I don't mind the little extra harshness at all.
I have the rears still to install, then its off to get the car fully aligned. (I already have springs, struts and swaybars installed).
-Charlie
Old 02-16-2005, 11:02 PM   #8 (permalink)
View markman's Photo Gallery
I've been wondering some of the same things. Energy Suspension also makes control arm bushings in a black "graphite impregnated" poly. I'm an engineer and I don't buy that you sprinkle a little graphite in and it won't just wear off the surface in 2 days. People talk about using marine grease to keep them quite.
I'm annoyed with some of the play in my suspension, like how you have ease off the brakes very gently or the whole thing kinda snaps back when the car comes to a rest. Maybe that's just a problem of the design compared to a double arm or wishbone. I'm thinking that big rubber bushing at the back of the control arm puts a lot of play into it, but maybe softens up the ride - at least until it's worn out. I'm not dying to make the any rougher than it already is. It's got 105K miles, but the arm bushings look OK. I don't know when or if they were replaced.
I've seen rubber replacement bushings and even cheap asian replacement arms with rubber bushings already installed.
Upshot is, I'd LOVE to hear anyones experience with changing out these bushings, either with rubber or poly or whatever. PLEASE PLEASE PLEASE!! Anyone with experience, please share!!
markman is offline   Reply With Quote
Old 05-18-2005, 05:35 AM   #9 (permalink)
View 89DLXV6's Photo Gallery
I just ordered a set of front control arm bushings, inner and outer, from Global Performance yesterday. Should be at my door Friday, and I'll be installing them next Wednesday.
Anybody have any major issues pulling the stock rubber out? Mine are so worn at 215,000 miles, I don't think they should give me much trouble. I'm just hoping I don't have to take them to a machine shop to have them pressed out.
89DLXV6 is offline   Reply With Quote
Old 05-18-2005, 12:56 PM   #10 (permalink)
white90dx's Avatar
I finally got all the rear bushings installed over the weekend. All of the bushings were do-able at home except for the rear lateral links. I used a two-jaw puller and a socket to press the bushings out in my garage and most of the bushings are two piece when the go back in. I went to a shop to get the one-piece bushings put back in.
The car got aligned two days ago, and I will be driving the car tonight for the first time... The alignment guy was very proud of his work at says that all the suspension problems are gone (not bad for a 4-wheel alignment for $50!). I'm really looking forward to having the suspension 'done'
-Charlie
PS. I have an extra set of the rear bushings if anyone wants to buy them.
Old 05-18-2005, 01:23 PM   #11 (permalink)
Pochacco Owns Me
atobe's Avatar
whoa how'd u get aligment for so cheap ? i paid like 95$ a year ago
Old 05-18-2005, 01:34 PM   #12 (permalink)
Charlie - Glad to hear the front bushings aren't too much of a pain. I know I won't have any issues with re-installation, gotta love 2-piece I'm also going to sand down and paint the control arms while they are off, they aren't looking too pretty. Also doing set of OEM coils and Monroe Sensa-Trac shocks (This is my daily driver) But other than Intrax, does anyone even make aftermarket springs for a 2G V6? How much do you want for the rear set, and which ones are included? Let us know how you like them!
Atobe - I only pay $49 for a 4-wheel alignment at Merchants Auto (Tire Kingdom subsiduary) in Maryland. I'd be bitter if I had to pay all most $100 for that!
Peace - Matt
Old 05-19-2005, 11:19 AM   #13 (permalink)
Beams SV21
da_horse's Avatar
View da_horse's Photo Gallery
sounds good Charlie, keep us updated on the results. For all those who are curious on prices (in AUD) for the SuperPolyPro bushings:
Front
Lower Control Arm : $ 37.20
Swaybar to Lower Control Arm : $ 60.00
Swaybar to Chassis : $ 32.40
Control Arm Inner : $ 29.50
Control Arm Outer : $ 29.50
Rear
Trailing Arm: $ 68
i didnt get prices for rear swaybar as i've got poly ones with my whiteline RSB
total : $ 256 AUD
Cheers
Huy
1989 BEAMS 3S-GE SV21 Camry
da_horse is offline   Reply With Quote
Old 05-19-2005, 05:30 PM   #14 (permalink)
white90dx's Avatar
Cheers
Woo ha, I got the car back from the alignment last night. You can definitely feel EVERY imperfection in the road, even with the 70-series tires I still have on the car. The car sticks to the road way better than it should for the crappy tires that are on there.
I still have an issue though - the front end shakes on acceleration. It happens less often now that it is aligned. All of the suspension componenets are fine, as far as I can tell... I'm going to be checking the wheel bearings, steering rack bushings and re-doing the custom suspension crossmember (custom to clear my exhaust) to see if any of that fixes the problem.
-Charlie
Old 05-29-2005, 02:27 PM   #15 (permalink)
Installed my SuperPro Inner and Outer LCA Bushings on Thursday. Very Impressed. I didn't do the complete set as Charlie did so I can't speak on that. But with just doing the Front LCA bushings, I am getting zero additional road feedback. I definately attribute this to the softer type of poly SuperPro uses. Chassis vibration is nowhere near what I was getting using the Energy Suspension kit on my 88 CRX Si and 97 Eclipse GST. Turn in response is, of course, much improved, as compared to the mostly dead bushings I removed. For the price, you cannot go wrong with these.
Picked mine up from Global Performace via Zach Thomas. Have nothing but positive feedback for them. He quickly answered the couple questions I had, shipped same day, and I had them in my hands 2 days later. Link provided by ZFreeman above.
One further note... The Outer Bushings, or Sway bar Mount bushings, where easy to remove. Just need to chisle out the metal ring on either side of the LCA and they pop right out with the proper amount of force =) The inner bushings on the other hand.. Well, took me 2 hours to completely remove the pass. side bushing - ended up running the driver side out to a local machine shop and had it pressed out for $5. I reccommend just having them both removed at a machine shop if you have one close by, couldnt imagine them charging more that $15 to do both sides, and will only take them 5 or 10 minutes.
Happy Motoring - Matt
