What are some possiblke things that would cause such a noise on a neglected 151,000 camry?
Its possible that the valves are outta adjustment (vavle lash). I have 165,000+ miles on mine and it ticks a little bit but, nothing like what your talking about.
What is an easy way to check for a slipped belt?
There is no easy way to check it.
1. Remove the spark plugs (makes it easier to turn the engine over by hand).
2. Using a socket and rachet on the bolt of the crank pulley turn the engine over till the #1 piston is at TDC (top dead center).
You'll know the #1 piston is at TDC by lining up the mark on the crank pulley to the 0 degree mark on the timing belt cover.
3. Remove the timing belt cover.
4. Check and see if the mark on the timing belt lines up with the mark on the camgear.
5. Tell your buddie to buy a Chiltons, Haynes, or Toyota repair manual for his car. :grin:
_________________
88 LE (Team C-Spec)
"Boost 0wNz j00!"
<font size=-1>[ This Message was edited by: 88 LE on 2001-10-05 06:47 ]</font>
