Has it been raining, or wet out lately? I drove about 250 miles through pouring rain, and had similar problems, it would crank, but once you let go of the key, it shut off, which usually means that there's water in the fuel line. I did the same thing, kept cranking it and manually revving it, I also reset the fuel injector by pulling the EFI fuse, letting the car crank a few times, then putting the fuse back in. I haven't had any troubles since, but I do realize that there's probably something wrong somewhere...
