1987 Camry with blown engine... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-27-2005, 05:02 PM   #1 (permalink)
View Hammer's Photo Gallery
Hello to all,
I'm new here. I just purchased an 87 Camry and to my dismay there is a quarter size hole in the engine on the right lower side. I am not sure what caused it but I think my best bet would be to get a different engine, right?
The car model# is SV21L-EUPNKA.
I believe this is a 2nd generation Camry. If I were to look for a different engine that went in without any modifications needed, what should I look for?
Thanks so much.
Hammer is offline   Reply With Quote
Old 05-27-2005, 05:31 PM   #2 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
The can you have as a 3S-FE 4-cylinder engine. Your best bet would be to swap in a working 3S-FE for your busted 3S-FE. Keep in mind this is my no means a performance enhancing engine.
If you are looking for more performance out of an engine, reply here.
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 06-01-2005, 04:38 PM   #3 (permalink)
I don't need an engine with more performance. Do you know if the crankshaft is a 6 or 8 bolt on?
This is the question the auto recycle place is asking.
Thanks for responding.
Old 06-01-2005, 05:05 PM   #4 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
You should have the 6-bolt crank if it is the orignal motor. If you are worried, see if they will send the flexplate with whatever motor they send.
-Charlie
Old 06-02-2005, 05:28 PM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ I agree.
Theres a way a check based on the manufacturing date of the car. I forget what the cutoff was though.
But early gen 2 Camrys w/3S-FE have a 6 bolt crank and the later ones have a 8 bolt crank.
Whoever you buy the engine from should supply you with the correct flywheel (manual transmission) or flexplate (automatic transmission).
"Skoolin' the unlearned!"
