Originally Posted by chronoti
yes that switch would be it. i dont have a repare manual for the gen 2 so i cant tell you exatcly what it's spota be at to check those things and i dont want to tell you anything wrong
Right on, I'm going to replace both of the compressor cut-off switches (speed sensor and dual-pressue) As well as the drier and expansion valve. That is regardless if they are bad, as I know the drier needs to be replaced when you retrofit either way and they are all fairly cheap parts new. I found that information on the clutch coil resistance, posting it for future searchers:
"Hook black lead of meter to ground and with clutch unplugged
probe wire going into clutch coil with red meter lead,you should get a reading
of under 3 ohms.anything higher than 5 ohms is too much and would indicate a
faulty coil."
Does that sound about right?
I'm also going to have the system vacuumed AND then I'll remove the Evap core and flush it, as well as checking the core temp sensor, prior to refilling with R134a. I don't want to risk any oil cross contamination so I'll just do it right the first time.
I'm going to pop the belt on Thursday when I have off and try to spin the compressor, hopefully it's not seized. If so, I'll get a new compressor as well.
-Matt
Edit: One more question. Is the clutch coil built into the clutch, part of the compressor, or standalone? I found that you can buy just a clutch coil from Toyota, but it is about the same price as an aftermarket clutch.
