16x7 on my gen 2 +40 or +35? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2005, 11:52 AM   #1 (permalink)
View Wangan's Photo Gallery
2nd Generation 16x7 on my gen 2 +40 or +35?
I'm finally going to get the wheels for my car. I'm going to run some 16's. however I want the rim to line up with the fender of my car. it seems on the gen2's they have a wider track in the front then in the rear. I searched for cars with the size i've mentioned and +38 offset where the front wheel lines up perfectly with the fender but the rear wheel is still deep inside the fender. Since I want the car to be even looking all around. what offsets should I be going for. I want some rota "Track R" and they only come in +35 or +40. I was thinking I'd need +35 for it to line up with the fender in the front. But what will I need for it to line up in the fender in the back? +35 with a spacer?
Thanks ahead of time.
Anthony.
http://i4.photobucket.com/albums/y11...3385Medium.jpg
Here's my camry ^
Current: B+G Springs, KYB GR2 Struts, Erebuni Bodykit(uninstalled), 3SGTE/E52 swap, Crane HI-6S Ignition Box, Crane Timing Retard Controller.
Plans: Here
Wangan is offline   Reply With Quote
Old 06-22-2005, 12:37 PM   #2 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
Anthony.
Anthony; the lower offset is always better
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 06-23-2005, 12:09 PM   #3 (permalink)
Thanks man I'll go with +35 all around then and if needed. Add spacers to the rear. I don't think +35 will stick out the front fender. Well I hope not.
Here's my camry ^
Plans: Here
Old 06-23-2005, 12:28 PM   #4 (permalink)
Me and my Bebe, Bianca
CamryPunk's Avatar
View CamryPunk's Photo Gallery
Either offset will work.
Yukio Taira
-1992 4 door Bomex'ed out, Nitrous Express Sport'n, Rippmods SuperCharged Camry
-1992 4 Door EX Honda Civic 5 spd.
-2002 Subaru WRX Wagon... full JDM goodies. My new show car.
CamryPunk is offline   Reply With Quote
Old 06-23-2005, 05:43 PM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
It won't stick out past the fender.
I had 16x7 (+35 offset) and 205/45/16 on my gen 2. No probs at all.
"Skoolin' the unlearned!"
Old 06-23-2005, 06:56 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
I have 7 inch wide wheels on my gen2, the fronts are ok but the rears are so close to the struts the tires almost rub them
Old 06-23-2005, 09:51 PM   #7 (permalink)
Broken Toy Hoarder
View hirosada's Photo Gallery
I'm running 17x7 +35mm with 205-40-17 and lowered 1.5" on Intrax springs with Tokico HP's.. I've got minor rubbing up front, but if you're at stock height you'd be more than fine. Yeah and they don't stick out.
hirosada is offline   Reply With Quote
Old 06-24-2005, 10:48 AM   #8 (permalink)
Nah I'm planning on going +35 offset all around but as i've mentioned the rears seem to be more inward than the front so I'm planning on sticking some spacers in the back to bring the rim outward to line up with the fender on top. I should have nothing to worry about.
Here's my camry ^
Plans: Here
Old 06-25-2005, 04:36 PM   #9 (permalink)
View Camryfellow's Photo Gallery
I've got +35 offset on my 15's, and 25mm spacers behind, works perfectly!!
Camryfellow is offline   Reply With Quote
