89 Camry brake depression prob - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2005, 11:51 AM   #1 (permalink)
View yotasrule's Photo Gallery
2nd Generation 89 Camry brake depression prob
I searched and could not seem to find my problem, maybe I just don't know how to search for it. Anyway, while running the brakes seem to slowly let out while braking as i stop. The brake just keeps givin slowly until they're almost all the way pressed down. I can pump the brakes and it seems to regain some pressure but looses almost as fast. What should I be looking for? The brake fluid under the hood is between the lines. Could there be a clog?? Could this lead to total brake failure? I've been driving for a couple days like this and its has me worried that the brakes will fail. Stopping power has reduced a bit as well.
Thanks for any insight
yotasrule is offline   Reply With Quote
Old 07-07-2005, 12:50 PM   #2 (permalink)
View karazy's Photo Gallery
If there are no signs of leaking, like you said, then it is probably the master cylinder. The o-rings will wear out after awhile, allowing fluid to bypass back into the reservoir.
karazy is offline   Reply With Quote
Old 07-07-2005, 02:09 PM   #3 (permalink)
View Wangan's Photo Gallery
It's the master cylinder. When I got my 87 I had the same problem. Change that and bleed the system then you should be good to go.
http://i4.photobucket.com/albums/y11...3385Medium.jpg
Here's my camry ^
Current: B+G Springs, KYB GR2 Struts, Erebuni Bodykit(uninstalled), 3SGTE/E52 swap, Crane HI-6S Ignition Box, Crane Timing Retard Controller.
Plans: Here
Wangan is offline   Reply With Quote
Old 07-07-2005, 06:27 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
master cyl
Old 07-10-2005, 11:11 AM   #5 (permalink)
Can i get away with just changing the ring? or is the whole cylinder bad?
Old 07-10-2005, 03:32 PM   #6 (permalink)
Yes, there is a rebuild kit.
Old 07-10-2005, 06:47 PM   #7 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
just go to napa and get a new one
Old 07-11-2005, 01:45 PM   #8 (permalink)
Well replaced master cylinder and while trying to bolt on the last of the 3 mounting bolts to the booster the friggin bolt broke . Anyone know if the bolt can be removed? From the hayes manual it looks like its built into the brake booster. Hate to have to replace the whole booster over one bolt.
Old 07-11-2005, 03:20 PM   #9 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
its part of the booster
