91 4cyl auto axle question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-20-2005, 11:46 PM   #1 (permalink)
View ashley's Photo Gallery
Getting the lower joint seperated & outer portion of the pass side axle out was easy.It was when I tried pulling the remainder out. I have the type that's held in by a clamp & bolt at the mid-bearing portion which I had removed & still couldn't get the "half shaft" out by the suggested of using a hammer & punch.Any help would be great.
ashley is offline   Reply With Quote
Old 07-21-2005, 07:48 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
1. Unbolt the mount from the back of the block.
2. Remove axle from tranny.
3. Then try to seperate the axle from the mount.
"Skoolin' the unlearned!"
Old 07-21-2005, 08:32 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
i cant believe somebody saw that thread and actually tried it 88
Old 07-22-2005, 04:20 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
^ I saw that thread too.
Hammering on the axle and mount is not a good idea. If you break the bolts on the mount you'll have a bigger problem to deal with.
I've had to deal with a seized axle. What I did was unbolt the mount with the axle stuck in it. Clamp the mount in a vise, soak the bearing with penatrating oil, and use a block of wood + BFH (big f'in hammer) on the end of the axle.
Old 07-22-2005, 09:32 AM   #5 (permalink)
removing the bracket sounds like a good idea. I'm going to have at it again hopefully in the next few days. thx for the advise
