1MZ and the E153 and the Gen 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2005, 09:08 AM   #1 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
2nd Generation 1MZ and the E153 and the Gen 2
Would my E153 (1993 model) be up to the task of holding the power of a 2003 model 1MZ-FE V6??
And, in terms of mounting, how would the 1MZ go mounting into the Gen 2? What sort of wiring tasks would there be. This is all assuming there was a motor, ECU and loom to play with....
Also, what sort of power does the Gen 5 1MZ put out?? Opinions on how it would go in the Gen 2? It would be fully rebuilt, balanced, ported/polished...
Thanks.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 07-31-2005, 09:54 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
FWOAH! youre going all out!
not sur eif youre going to fit the engine in height wise... width may be an issue too o_O
terrastrife is offline   Reply With Quote
Old 07-31-2005, 09:57 AM   #3 (permalink)
Black since 1985
View Ruffrydasean's Photo Gallery
may have to cut into some sheet metal they way they have to, to fit the H22A engine into the CRX... so it may be doable... i dunno
Lexus officially announced that they arent f***ing around anymore
"We aint f***in' around anymore." - Lexus Employee
Ruffrydasean is offline   Reply With Quote
Old 07-31-2005, 10:19 AM   #4 (permalink)
VeeZed
Hehe..just after some opinions for the moment.
If cutting were involved, i would not tackle it, i want to retain my Gen 2 body hehe.
Even though it's a different block etc, would Toyota have really made it THAT much bigger? I mean, the V6 i have in mine is fairly big for the Camry engine bay, so i can't imagine that the 1MZ is going to be TOO much different externally. Dunno.
Old 07-31-2005, 12:42 PM   #5 (permalink)
View 25psi's Photo Gallery
What about a 3VZ......similiar power and the same engine family which may end up being an easier swap.
-Jim
91' Camry DX 3S-FE
25psi is offline   Reply With Quote
Old 07-31-2005, 12:44 PM   #6 (permalink)
the 3vz only just fits then gen3 bay in height, so its probably not gonna clear th gen2 bonnet.
Old 07-31-2005, 01:18 PM   #7 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
this is why they make super charger hoods .......
your e153 will hold it fine.
new mounts, dont know how well the gauges would work.
engine would be 51cm long (housing to pullys)
why do the 3vz? you might was an older 1mz i think in 03 it doesnt have a throtal cable and that would be more annoying work to re do the gas pedel. shoot for a 01
^ and leaving it that way!
Old 07-31-2005, 02:35 PM   #8 (permalink)
hey jetspeed, why dont you bottle feed the car?
Old 07-31-2005, 03:19 PM   #9 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
You are becoming more ambitious aren't you? I think the 3VZ Under your hood would be badass.
BlueFusion6851 is offline   Reply With Quote
Old 07-31-2005, 03:31 PM   #10 (permalink)
View yosh's Photo Gallery
Why not 97-01 1MZ and slap on a s/c?
2000 Camry LE V6
TRD Supercharged
yosh is offline   Reply With Quote
Old 07-31-2005, 04:32 PM   #11 (permalink)
jackfrost1031's Avatar
View jackfrost1031's Photo Gallery
because you can't intercool a TRD supercharger.
you would really be best off looking at a 1mz car and yours side by side, making notes on clearnances, mounts, and the like. You should take a measure of how high the intake manifold comes above the heads, and how high it comes up on the fender from a profile. If all else fails, you can have a custom manifold done, and get some ITB's going while you're at it.
1996 T100 2wd 5vz-fe
jackfrost1031 is offline   Reply With Quote
Old 07-31-2005, 05:34 PM   #12 (permalink)
Black since 1985
I was looking around for one the other day and couldn't find one.. Why exactly isn't it possible to IC it??
Old 07-31-2005, 06:11 PM   #13 (permalink)
because its a screw charger. you need a root (so you can plumb in the cooler after the blower).
other options are available, you can no2 or co2 cool the initial charge air.
Old 07-31-2005, 09:18 PM   #14 (permalink)
VeeZed
Hmm..some interesting ideas.
Bottle feed..no thanks..im after pure NA power. Possibly supercharging. Plus i don't like it complete illegality here! The reason i am interested, is because i've been offered a 1MZ from an 03 Camry, with ECU and loom. I'm not "looking" for one per say..i was actually looking for a 2VZ, which I want to build up and swap over.
Dimensions are the biggest thing..and if it didn't fit, i wouldnt do it. I really don't want to cut and thing major, and don't want to have to cut into the bonnet, just to fit the engine. The guage cluster would be interesting for sure..not sure how it would work. As far as mounts go, i've got 3 of them done already, when i did the gearbox...so the only one i'd have to worry about is the dogbone mount. That would have to be custom done for sure. A 3VZ would be ok too i suppose, but the 1MZ ultimatly has more power and is lighter and newer. Although the 3VZ has more torque, i think i'd rather a newer engine. The "fly by wire" accell would be an issue too.
Old 08-01-2005, 12:05 AM   #15 (permalink)
and?...
2000 Camry LE V6
TRD Supercharged
