Replacing thermostat for 91 Camry. - Difficult, or do-able?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2005, 04:33 PM   #1 (permalink)
View 89_3SFE's Photo Gallery
I've got a V-6 1991 Toyota Camry and I have located the Thermostat. I think it needs to be replaced because after about 10 minutes of freeway driving with A/C on, it creeps up past halfway point, but never goes beyond it. Then the A/C kinda gets warm, but that's another discussion.
I need to replace the thermostat and I want to know if it is a difficult job for just myself. Also, what other tools do I need besides very basic tools such as a socket wrench. I took a look at it myself and it looks pretty hard to get there. I have small arms and hands, so maybe that'll be to my advantage. If you could let me know, thanks!!
89_3SFE is offline   Reply With Quote
Old 08-01-2005, 05:55 PM   #2 (permalink)
jackfrost1031's Avatar
View jackfrost1031's Photo Gallery
I did it once, I didn't remember it being very hard. You have to disconnect the altenator I think to get to it, just be sure to remember how things bolt back together.
oh, and don't forget the little gasket on the thermostat.
1996 T100 2wd 5vz-fe
jackfrost1031 is offline   Reply With Quote
Old 08-01-2005, 11:41 PM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
SHouldnt be very hard at all. Like jackfrost said may have to move the alternator to get to it easier. 2 or 3 bolts and the housing comes off. Replace the t-stat and the oring around it put it back together fill with coolatn/water and let it run til it heats up to get all the air pockets out. Once the t-sta opens up top off your coolant and put the cap back on. Oh yeah when you are ltting it heat up turn the heat on so you get coolant into the heater core and dont end up with air pockets. shouldnt take more than about thiry minutes probably and alot of that is waitng for the coolant to drain and then wating for the t-stat to open up making sure it is full.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
