No Gen 2 Camry's have headlight ON buzzers
You MUST install it yourself (EASY) look below for instruction..
Also The ONLY models that turn off headlights when the key is out and the drivers door is opened are the LE MODELS ONLY (unless modified by me).
if you don't want to jump your car every time you leave the lights on do this;
- Buy a $4 chime from Radio Shack
- using a 10mm socket, remove lower panel from under steering wheel OR
- locate wire coming from adjustable dash light knob
- Verify that 12 volt when lights on
- Connect that to the + side of buzzer
- Connect the - side of buzzer run wire to drivers door switch wire.
- Replace the panel
- Test by tuning lights ON then open drivers door ( buzzer ON)
