I have a 1990 toyota camry v6 dlx and my reverse lights come on when the car is started and stay on. I want to know if anyone know where the backup light switch is and if i can get to it from under the hood? I just want to see if thats the issue
The backup switch is part of the neutral safety switch, front bottom of the transmission a fairly large connector. If the lights are still one after removing that connector check for frayed wires near the left side trunk hinge. I am assuming you have the auto transmission, or are you one of the lucky ones to have the 5-speed?
if its the manual the switch is on the top of the transmission iirc. a two wire connect i bleive. ill be home in a couple hours to confirm if you do indeed have the manual trans
Thanks dem2757,especially the part about the e brake cause mine doesn't work but thats another issue,I probably wont be able to check the switch for a couple of days as im not allowed to work on my car where i live,I'll give u an update after im able to check it out,thanks again
Yeah some of their rules are crazy,I've worked on my car before at my complex but didn't realize the rules until later on and yeah i have taken the bulbs out
