91 replaced Water pump& timing belt 3sfe timings off now??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2005, 04:11 PM   #1 (permalink)
View Toyotasrgreat!'s Photo Gallery
USA 91 replaced Water pump& timing belt 3sfe timings off now???
We replaced the water pump/ timing belt on a 91 camry. We got it all back together now the timing is off. ( 4 cylinder engine 3s-fe) I think the cam shaft timing is wrong. We set the crankshaft pulley@ 0 on the lower timing belt cover, cylynder 1 @ TDC. We had the camshaft pulley on the valve timing marks from the factory. We are using a new timing belt. Can we get the timing correct without a timing light? What marks do we use to get the camshaft and cranksaft to line up on the new belt to make timming correct?
Toyotas rule!
91 Camry 156,000
92 4X4 delux cab 198,00
97 4 runner 98,000
89 MR2 TOTALED!!!!
88 Celica GT TOTALED!!!!
Toyotasrgreat! is offline   Reply With Quote
Old 08-23-2005, 04:52 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
http://www.yotarepair.com/3S-FEtimingbelt.html
"Skoolin' the unlearned!"
Old 08-24-2005, 05:57 AM   #3 (permalink)
Don't know how we missed that important step. We never turned the crankshaft two revolutions...... guess we should have left this job to the trained professionals.........
Thanks for the help.
Toyotanation forum has helped me repair my toyotas 2 times now.
Toyotas rule
91 Camry 156.000
92 4x4 Delux cab 198,000
97 4 Runner 98,000
89 MR2 TOTALED!!!!
Old 08-24-2005, 12:59 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
After the belt is installed, the crank needs to be turned 2 full revolutions (720 degrees, TDC to TDC).
The cams turn at half the speed of the crank. 720 degrees of crank rotation = 360 degrees of cam rotation.
Only then can you check the timing marks (crank and cam).
