Need Wiring Help!!! 1991 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2005, 01:24 PM   #1 (permalink)
View locker's Photo Gallery
I need a wiring diagram for the Automatic Tranny from a 1991 Toyota Camry!!!
Can somebody please help!!!!!!!!!!!
locker is offline   Reply With Quote
Old 09-23-2005, 04:16 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
A140E, A140L, or A540E?
Are you looking for anything specific?
I have the wiring diagrams for ECT and A/T indicator, and over drive for a A140E.
There is a manual just on the tranny, which I don't have. ECT (A140E) diagnosis manual.
"Skoolin' the unlearned!"
Old 09-23-2005, 12:03 PM   #3 (permalink)
I don't know the exact tranny code but the tranny is from a 1991 with a 3sfe
Old 09-23-2005, 07:40 PM   #4 (permalink)
Thanks anyways man... couldn't find the info fast enough so im just going to swap the 5sfe for a 3sfe that came with the tranny.
Second motor swap for the wagon in 3 months. 3sfe to 5sfe and back again
Old 09-23-2005, 10:25 PM   #5 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
You swapped a 5SFE into a Gen 2?? If so, you should do a write up on it, some ppl here would be very keen to know what was involved.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 09-26-2005, 07:44 AM   #6 (permalink)
I suppose I could. It was actually quiet an easy swap to do. I simply used the shortblock to avoid any wiring issues. Tore the 5sfe down to just the head and block and bolted on all the 3sfe equipment IE (intake manifold, distributor etc...) everything bolted on without an issue. The only way you'd know its a 5sfe rather than a 3sfe is if I told you... the valve covers can even be swapped.
Old 09-26-2005, 07:47 AM   #7 (permalink)
sorry really crappy pic but you can see that the intake manifold is from the 3sfe and the valve cover if you could read it says 2000.
So the swap wouldn't work as the wiring harness are completely different once inside the car. So this is what I need to figure out.
On the tranny from the 87 GT there is only two wires coming off it. 1 power 1 ground im assuming. Now on the harness from the camry there are 5 wires. Im assuming the extra wires are for the ECT button on the console but not too sure. What Im trying to figure out is what color are the wires going to the tranny are for power and ground.?? Or the wiring diagram from the 91 camry with the 3sfe and automatic
