91 Camry brake and battery warning lights ON - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 1st & 2nd Gen (1983-1986) & (1987-1991) Toyota Camry Discussion for years 1983-1986 & 1987-1991. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 12 Old 03-08-2006, 05:40 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
After starting, my 91 Camry brake and battery (or alternator) warning lights suddenly came ON for may be 2-3 minutes then OFF for the rest of the trip. Can anyone tell me what is wrong and need to be done. Thanks for the HELP!
chopper75 is offline
post #2 of 12 Old 03-08-2006, 05:50 PM
Grenaded piston
88 LE's Avatar
Quoted: 3 Post(s)
Most likely cause of that is a worn/bad alternator.
"Skoolin' the unlearned!"
88 LE is offline
post #3 of 12 Old 03-08-2006, 09:47 PM
Quoted: 0 Post(s)
yep its a bad alternator. it happened to me before.
The Black Camry is offline
post #4 of 12 Old 03-08-2006, 09:49 PM
Quoted: 0 Post(s)
Another vote for the Alternator. Happened to me also.
Dave G is offline
post #5 of 12 Old 03-08-2006, 10:09 PM
Quoted: 0 Post(s)
Again alternator~...
Kitto is offline
post #6 of 12 Old 03-08-2006, 11:01 PM
N/A bites
Tercel GTS's Avatar
Quoted: 79 Post(s)
You sure it's not a loose spare tire?
j/k
雄のハヤブサ
Tercel GTS is offline
post #7 of 12 Old 03-09-2006, 04:58 AM
Grenaded piston
88 LE's Avatar
Quoted: 3 Post(s)
Its low on alternator fluid and/or the alternator timing is off. Need a special alternator timing light to check it though.
88 LE is offline
post #8 of 12 Old 03-09-2006, 09:54 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I will have the alternator check out and post the result. Thank you everyone for the inputs.
post #9 of 12 Old 03-09-2006, 10:38 AM
Senior TN Member
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Quoted: 4 Post(s)
Check the tension on the belt, it may be slipping when you start the car.
It worked fine until I fixed it!
csaxon is offline
post #10 of 12 Old 03-10-2006, 04:07 AM
hyo
I love my camry
Quoted: 0 Post(s)
2nd Generation yup
yupp thats the alternator. cause i had the problem today, and then when i came out of work, my alternator died *cries*
hyo is offline
post #11 of 12 Old 03-10-2006, 07:30 AM
Quoted: 0 Post(s)
ditto here on my accord (delphi) right at 100k
hmm, I wonder if one can just change the brushes and call it a day? will be much much cheaper than a new alternator.
stockrex is offline
post #12 of 12 Old 03-13-2006, 12:07 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Just a reply to everyone who gave me helpful information. Yes, it is the alternator! During the weekend, I measure the voltage across the baterry with the engine running and sure enough the DVM read 12.15VDC while it should be between 14.10 - 14.40 VDC. I went to autozone bought a new one and put it in. The problem is fixed. Thanks again to every one.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 1st & 2nd Gen (1983-1986) & (1987-1991)
User Tag List
Linear Mode Linear Mode
Back
