How to remove v6 alternator? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 1st & 2nd Gen (1983-1986) & (1987-1991) Toyota Camry Discussion for years 1983-1986 & 1987-1991. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 9 Old 03-20-2017, 11:54 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
I'm in the process of replacing my thermostat in my ES250, which in order to do, I have to take the alternator out. I've removed all the bolts and the alternator is free, but this group of wires coming from above the timing belt is in the way! I've tried everything I can think of to move the wires around, and while there is some play, I still can't get the alternator out. I can't unplug them because they're plugged in somewhere below the alternator and seem to split in 3 different directions. Is there a trick to doing this? Does anyone have any suggestions?
Also, does anyone have any idea what this orange stuff is that's leaking? The car has been sitting in the garage for about a month now without being started, and this has happened within the last week or so.
KYrac is offline
post #2 of 9 Old 03-20-2017, 12:31 PM
Toyota Collector
71Corolla's Avatar
Quoted: 1254 Post(s)
Remove the connector from the 'stat housing, unclip the plastic wire sheath from the timing belt/engine backplate. After that you'll have enough wiggle room to disconnect the wires going to the A/C compressor.
The orange stuff looks like rusty coolant. Or maybe orange coloured coolant.
Parts For Sale
2000 Lexus ES300 Millenium Edition
1993 Camry V6 LE
1990 Camry LE V6
1990 Camry LE V6 WAGON
1987 Camry LE I4
71Corolla is online now
post #3 of 9 Old 03-20-2017, 12:40 PM
Moderator
Quoted: 419 Post(s)
That looks suspiciously like old, silty Dex-Cool.
95 Camry 5S-FE 168k
95 Camry 5S-FE 125k
00 Camry 5S-FE 187k
99 ES300 243k
01 ES300 151k
01 Insight 137k
insightbrewery is online now
post #4 of 9 Old 03-20-2017, 08:53 PM
Senior TN Member
dem2757's Avatar
Quoted: 252 Post(s)
ive had luck in loosening the bracket that the pivot adjustment is on if the alternator is being particularily tricky to remove.
looks like a coolant leak to me.
1990 Camry LE 2VZ-FE Auto 312,680 miles Retired
1991 Camry DX 2VZ-FE 5-Speed 113,000 miles
2010 Civic SI K20Z3 6-Speed 70,000 miles
dem2757 is online now
post #5 of 9 Old 03-20-2017, 09:15 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Thanks for the suggestions, I will try those and see how things go!
It does look like coolant, but I was confused by the orange color, since I drained the radiator and the coolant came out red. It was just as clean as after I flushed the system and refilled it with new Toyota coolant, so I'm not sure why this coolant would be orange. I'm replacing the thermostat in hopes that the car will stop overheating, as it has done since the radiator blew and a new radiator hasn't solved the problem.
KYrac is offline
post #6 of 9 Old Yesterday, 01:01 AM
Moderator
Quoted: 419 Post(s)
If that doesn't work, try the glove trick to see if your 2VZ blew a head gasket. That murky orange coolant could be your red coolant with a tiny bit of oil in in. Not quite chocolate milkshake, but will get there.
Or rent a block tester, or look for bubbles in the coolant expansion tank, etc. etc.
95 Camry 5S-FE 168k
95 Camry 5S-FE 125k
00 Camry 5S-FE 187k
99 ES300 243k
01 ES300 151k
01 Insight 137k
post #7 of 9 Old Yesterday, 12:03 PM
3s-gte in a Camry?!?
white90dx's Avatar
Quoted: 422 Post(s)
iTrader Score: 6 reviews
Make sure the radiator cap is sealing correctly and holding pressure too.
-Charlie
89 Camry Alltrac LE 3S-GTE 5spd
99 4Runner SR5 4WD
Previous: 88 Camry Alltrac LE 3S-GE BEAMS, 90 Camry 3S-GTE, 90 Camry DX
white90dx is offline
post #8 of 9 Old Yesterday, 02:27 PM
'91 ES 250
Quoted: 56 Post(s)
"A new radiator didn't fix the problem"
I've stripped mine all the way down to the heads, and had the valves and heads remachined, installed new gaskets, etc. The head gaskets were in good shape, no leaking.
I had exactly the same problem as far as mystery overheating. Of the two main causes of overheating on the 2vz-fe 6cyl (including those which dem2527 and others were trying to get me into) were, gasses in the radiator, failure of the fans:
Air/hot gasses in the coolant system, usually after a chronic overheating caused by fan failure (correctable). This system requires a Lisle or Worthco radiator funnel kit. The funnel kit has a large capacity (around a gallon of coolant), and fits tightly with the top of your radiator. It allows you to keep the radiator fluid above the uppermost level in the engine, allowing hot air to escape, steam, and coolant to go in. The longer way around, is to fill the system:
** Fill it. Don't cap it.
** Start the engine
** When the engine has started to warm up a bit, Open the bleed bolt. It's in the back, follow the top radiator hose back to the engine, this is the hot return. There is a bolt right next to the hose connection. Open it up and you will see a little hole near the top of the threads, the bolt is hollow and those let hot coolant gasses escape.
** Keep the radiator topped up, and as the engine runs hotter and gasses escape, eventually the foamy fluid will appear, then just fluid. Close the bolt, check the level, close the radiator cap. If you had the lisle funnel kit, you would stop here.
** Overfill your reservoir.
** Drive the car a little bit, until fully hot.
** It's at this point that it's a good idea to stop and check under the hood. When your needle is getting about half-way on temp, you should see the fans operating under the hood on the radiator. If you DON'T, this is a known failure of the 2vzfe. I spoke with a woman who spent 2,000 on the suspension on her identical car, and then the engine blew up because the fans failed around 200k, just like they stopped on mine, precipitating the overheating problem secondary to fan failure. Someone familiar with correctly functioning 2vzfe fans can comment on whether they work at all at lower temps. I never had them working on mine, and there are five pages of schematics to trouble-shoot the circuit.
** IF or IF NOT the fans are operating, shut the car down in either case.
** IF the fans are NOT operating, pull A/C relay #2. The round, metal relay underneath the hood near the battery in the box with some other relays. This turns off the passenger side fan. Open and remove the glove box, and remove A14. You will see two boxes, the top one upside down with the wiring hardness connector oriented up, the other one underneath, pointed down. I think A14 is the one on the bottom. This will cause (I think it's the brown wire) to be OPEN, causing the drivers side fan to run on full. If you want to stop this fan, ground the wire. Yes, your A/C may not work for the moment, but the driver side fan will run at full speed pulling about 15 amps, and the car shouldn't overheat. I will eventually replace 5 pages of overly complex nonsense with a PVM box that directly monitors coolant temp and runs the fans at whatever speed necessary. ($150).
** Let it cool for 20-30 minutes depending on ambient temp. Keep an eye on the reservoir level, and when it starts to drop, the car's cooling system is sucking in coolant to replace the gaps. Basically, you run the engine, heat it up, let it cool and keep the reservoir topped off, and do this a few times and the car will force out all gas and fill itself.
I replaced the stock radiator with an OSC model 21 radiator. Haven't looked back since. It cools better than the stock radiator, and seems built better.
1991 Lexus ES 250 ( Camry v6)
Castrol fully sythetic 0-40w
Fram Ultra Syn filter X8A (Landcruiser)
Valvoline Maxlife full syn ATF (tranny&ps)
John M is online now
post #9 of 9 Old Yesterday, 03:15 PM
Moderator
Quoted: 419 Post(s)
** Start the engine
Say, are you using this: https://www.amazon.com/Lisle-24680-S...ct_top?ie=UTF8
I bought that, but the caps they provide don't seem to clamp to any of my Toyotas. Originally bought it for a Hemi Magnum, and the cap was loose. Wondering if it's incompatibility or defective parts...this is an exact clone of the Miller funnel kit that the Magnum's FSM calls out.
95 Camry 5S-FE 168k
95 Camry 5S-FE 125k
00 Camry 5S-FE 187k
99 ES300 243k
01 ES300 151k
01 Insight 137k
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 1st & 2nd Gen (1983-1986) & (1987-1991)
User Tag List
Linear Mode Linear Mode
Back
