ES250 (2VZ) - Losing coolant like crazy - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 1st & 2nd Gen (1983-1986) & (1987-1991) Toyota Camry Discussion for years 1983-1986 & 1987-1991. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
 2Likes
post #1 of 33 Old 05-13-2017, 11:06 AM Thread Starter
Quoted: 17 Post(s)
(Thread Starter)
I'm losing coolant like crazy. My tank will be empty after driving and I had to add half a gallon to my radiator and tank just now to fill it up. What could be the issue?
sixrabbit is offline
post #2 of 33 Old 05-13-2017, 11:16 AM
short-throw dipstick
Quoted: 809 Post(s)
Leak or blown head gasket
95 Camry 5S-FE 168k
95 Camry 5S-FE 125k CRASHED BY "FRIEND"
00 Camry 5S-FE 187k
99 ES300 243k ALMOST DONE!
01 ES300 151k
01 Insight 137k
insightbrewery is offline
post #3 of 33 Old 05-13-2017, 01:14 PM Thread Starter
Quoted: 17 Post(s)
(Thread Starter)
Phewwwie. I'm certain I have a leak, I don't know where from though. Maybe the outer gasket edge of the rear bank because it leaks to the ground by the firewall. I only have 108,735 on this 2vz!!!! Blegh!!!!
post #4 of 33 Old 05-13-2017, 01:26 PM Thread Starter
Quoted: 17 Post(s)
(Thread Starter)
After topping of the coolant and driving 115 miles my reservoir is now to the full mark
post #5 of 33 Old 05-13-2017, 01:28 PM Thread Starter
Quoted: 17 Post(s)
(Thread Starter)
I topped it off before driving 115 miles
post #6 of 33 Old 05-13-2017, 01:54 PM
Quoted: 809 Post(s)
Do a pressure test, external leaks should become blatantly obvious.
I'm sure you already know this (and better than me) but the VZ engines have problems with head gaskets due to differing expansion rates between the block and heads.
95 Camry 5S-FE 168k
00 Camry 5S-FE 187k
01 ES300 151k
01 Insight 137k
post #7 of 33 Old 05-14-2017, 06:24 PM Thread Starter
Quoted: 17 Post(s)
(Thread Starter)
Block test did not turn yellow
post #8 of 33 Old 05-15-2017, 09:56 AM
Senior TN Member
dem2757's Avatar
Quoted: 284 Post(s)
If you tested the coolant and are looking for exhaust gasses to be in the coolant on the 2vzfe, thats not a guarantee its good. My 1990 had an internal leak, with no exhaust gas propagation, and it drank a gallon of coolant every 12 months.
1990 Camry LE 2VZ-FE Auto 312,680 miles Retired
1991 Camry DX 2VZ-FE 5-Speed 115,000 miles
2010 Civic SI K20Z3 6-Speed 70,000 miles
dem2757 is offline
post #9 of 33 Old 05-15-2017, 02:57 PM Thread Starter
Quoted: 17 Post(s)
(Thread Starter)
Yeah figure it's not 100% accurate. I'm pretty certain I have a really bad leak from the water pump though. Or from somewhere else in that area, the water drips down to the oil pan. My entire cooling system drained to the floor. I'm out of town and I can't really work on it now, so I might have to take it in. I have the parts with me though. Sorry, for derailing my own thread
post #10 of 33 Old 05-15-2017, 04:26 PM
3s-gte in a Camry?!?
white90dx's Avatar
Quoted: 449 Post(s)
iTrader Score: 6 reviews
Replace the radiator cap with a new OEM one. The steam released with a bad cap often isn't visible during/after driving...
-Charlie
89 Camry Alltrac LE 3S-GTE 5spd
99 4Runner SR5 4WD
Previous: 88 Camry Alltrac LE 3S-GE BEAMS, 90 Camry 3S-GTE, 90 Camry DX
white90dx is offline
post #11 of 33 Old 05-16-2017, 03:17 PM Thread Starter
Quoted: 17 Post(s)
(Thread Starter)
Can a bad radiator cap cause the water pump to drip also?
post #12 of 33 Old 05-16-2017, 05:16 PM
white90dx's Avatar
Quoted: 449 Post(s)
Nope! If you see any coolant in the thermostat area or coming out of the timing cover, you need a new water pump... One of the failure modes is the bearings, which then cause the shaft seal to weep/leak. If you do have a leak in that area, replace it ASAP before you have a catastrophic pump failure.
-Charlie
Glenn Morton likes this.
99 4Runner SR5 4WD
post #13 of 33 Old 05-16-2017, 05:26 PM Thread Starter
Quoted: 17 Post(s)
(Thread Starter)
Scheduled at Toyota for tomorrow! Everything under there is getting replaced even the seals
post #14 of 33 Old 05-16-2017, 08:24 PM
Quoted: 809 Post(s)
Broke these posts off into their own thread.
95 Camry 5S-FE 168k
00 Camry 5S-FE 187k
01 ES300 151k
01 Insight 137k
post #15 of 33 Old 05-18-2017, 12:22 AM
Quoted: 0 Post(s)
Thermostat?
Sent from my SM-G950F using Tapatalk
stubanger is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 1st & 2nd Gen (1983-1986) & (1987-1991)
User Tag List
Linear Mode Linear Mode
Back
