A little oil pooling - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 1st & 2nd Gen (1983-1986) & (1987-1991) Toyota Camry Discussion for years 1983-1986 & 1987-1991. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 5 Old 12-07-2012, 08:37 AM Thread Starter
Quoted: 5 Post(s)
(Thread Starter)
on my 1986 Camry LE 242k miles, noticing a little oil pooling below the seem for the head on the firewall side, she still runs fine....should I ignore that or look for further problems..
86ers is offline
post #2 of 5 Old 12-07-2012, 12:45 PM
3s-gte in a Camry?!?
white90dx's Avatar
Quoted: 422 Post(s)
iTrader Score: 6 reviews
Most likely cause is a valve cover gasket leak.
-Charlie
89 Camry Alltrac LE 3S-GTE 5spd
99 4Runner SR5 4WD
Previous: 88 Camry Alltrac LE 3S-GE BEAMS, 90 Camry 3S-GTE, 90 Camry DX
white90dx is offline
post #3 of 5 Old 12-07-2012, 04:09 PM
Quoted: 0 Post(s)
What I do is degrease the whole engine and engine bay then drive it a couple days then you should be able to see where the leak is.
1986 Camry 2.0 Not going to let it die currently 232,000 miles.
1999 Camry 2.2
1986 tercel wagon 2wd - sold
Lee250 is offline
post #4 of 5 Old 12-08-2012, 02:35 PM
Quoted: 85 Post(s)
In addition to the valve cover gasket mentioned by whitedx90 there is also a little plate back on the firewall side of the engine that covers up the hole where a mechanical fuel pump was used on older versions of this 2SE engine. They can also leak requiring a new gasket and a bit of silicone.
Mike
Mike Gerber is offline
post #5 of 5 Old 12-12-2012, 11:22 AM Thread Starter
Quoted: 5 Post(s)
(Thread Starter)
I always wondered what that sealed flange area was for...I checked a bit closer and wiped a tissue along the area right below the valve cover...not really any oil, pretty clean, but there does seem to be more oil type stuff present below the head seam, I fairly convinced then that the oil I see is from some oil seeping out along there. It's not major leakage....I've seen that from my other car and its valve cover...so I'll wait a while till better weather comes to take it apart.
86ers is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 1st & 2nd Gen (1983-1986) & (1987-1991)
User Tag List
Linear Mode Linear Mode
Back
