Re: UPDATE Re: 94 Toyota Corolla - question
"Gord Beaman" <gord@islandtelecom.com> wrote in message
news:9mfer11o3aflli3kie38offqoun9nnuqqk@4ax.com...[color=blue]
> spamalicious <spamalicious@verizon.net> wrote:
>[color=green]
>>Ray O wrote:[color=darkred]
>>> I do not know if it is standard practice to check the idler pulley or
>>> not,
>>> however, a competent technician should at least give it a cursory check
>>> when
>>> threading the new belt around it. I do not have a copy of the factory
>>> repair manual for that car, but my guess is that it does mention an
>>> inspection of the pulley.[/color]
>>Anyone have a copy of the factory repair manual so we can check?
>>I really appreciate all the help!
>>N.[/color]
> I'll bet it IS mentioned...sounds like it should be anyway...I'd
> follow this up If it were me. If it -is- mentioned then jump on
> them!...they directly caused your new belt to be wrecked, it was
> likely tighter than the old one and 'finished the idler pulley
> off'...this sounds like very poor work by the garage involved.
> Remember...the squeaky wheel gets the grease!...you don't owe
> them anything, certainly no reason to be 'nice' after they
> screwed you...
> -Gord.
> (use gordon in email)[/color]
The factory repair manual for the 97 Avalon specifically mentions inspection
of the idler pulley and tensioner when replacing the timing belt, including
procedures for inspecting the pulley and tensioner.
Ray O
correct the return address punctuation to reply
