Power window problem on '95 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 14 Old 10-29-2002, 05:13 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
The power window control on the Right front side of the car fails way too often, even from the driver side it sometimes won't work.
Can anyone tell me how to disassemble it and repair it?
Thanks.
Conundrum is offline
post #2 of 14 Old 10-29-2002, 08:30 PM
Quoted: 0 Post(s)
Yes, take the door panel off, then check your wires, something is disconnecting, most likely when you hit a bump.. other then that, im not sure
It's a midwest thaaang!!!
http://www.imagestation.com/album/?id=4291436091
Zeek321 is offline
post #3 of 14 Old 10-29-2002, 08:57 PM
Quoted: 0 Post(s)
like zeek said... try checking your wires and make sure theyre nice and tight... also try cleaning them. if that doesnt solve the problem it may be the window motor itself
tinman831 is offline
post #4 of 14 Old 10-29-2002, 10:09 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Where can I find a step by step guide of removing the door panel?
Thanks.
post #5 of 14 Old 10-29-2002, 10:44 PM
Quoted: 0 Post(s)
the gen3 camry door is a little hard to take off, but once you get it, you can do it with ease. try one of those do it your self guides, they're sold at most auto-part stores for around 15.00 i got mine on ebay for 12.00 but with ebay, you'll have to wait for shipping and stuff...
Zeek321 is offline
post #6 of 14 Old 10-29-2002, 11:43 PM
Quoted: 0 Post(s)
my power window motor in my driver's door is going out
It has gotten a lot louder and does not go up a smooth as before. Wonder how much this will cost :evil: [/i]
97' Camry XLE V6
Tex97 is offline
post #7 of 14 Old 10-30-2002, 12:06 AM
Banning is an art.
Silver Streak's Avatar
Quoted: 0 Post(s)
Sounds more like a relay problem, most likely dirty contacts. For instructions on removing the door, try a search on this site. It's been posted before but I can't remember the topic.
Good luck!
Silver Streak is offline
post #8 of 14 Old 10-30-2002, 01:18 AM
Quoted: 0 Post(s)
Must be a topic on speaker installs.
'99 Camry 5S-FE
PLRBEAR is offline
post #9 of 14 Old 10-30-2002, 01:06 PM
Senior TN Member
TheKevin's Avatar
Quoted: 0 Post(s)
iTrader Score: 6 reviews
You could have hit a bump or slammed the door too hard and caused something to disconnect or become misaligned. Same problem with my driver's side window. I thought I needed a new lift motor.
73 Celica ST
91 P/U
97 LS400
07 tC
09 Camry SE V6
TheKevin is offline
post #10 of 14 Old 10-30-2002, 04:54 PM
Quoted: 0 Post(s)
I just fixed my window on the drivers side. I took the door panel which was a bitch :evil: ! Once I got that off i took apart the motor and cleaned it. It works good it's like it's brand new ! Hpe you fix it! Oh yeah a new motor cost about 200$.
93' LE!
TeamBigBoy is offline
post #11 of 14 Old 10-30-2002, 06:00 PM
Senior TN Member
TheKevin's Avatar
Quoted: 0 Post(s)
$200? I got quotes from Toyota dealerships for under $100. If it is the motor, try to get a used one, if you don't mind.
73 Celica ST
91 P/U
97 LS400
07 tC
09 Camry SE V6
TheKevin is offline
post #12 of 14 Old 10-30-2002, 06:27 PM
Phi
Whine Connoisseur
Phi's Avatar
Quoted: 0 Post(s)
Thanks.
http://www.gibson99.com/camry/cmpl-faq/gen3-door-int-handle/
Phi is offline
post #13 of 14 Old 01-19-2003, 03:14 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I finally got the time to work on my window problem. I removed every screws I see, plus 2 plastic things. yet I still can't get my door off. It seems that something in the area of speaker is either stick to the metal part, or is stuck.
Need some more tips from the pros.
thanks.
post #14 of 14 Old 01-20-2003, 01:36 AM
Quoted: 0 Post(s)
I've been having problems with my window too. The passanger side goes up very slow and most of the time it won't go all the way up. I have to go up and down until it decides to go all the way up. I figured it was the motor but I'm gonna check the wires and stuff also. This seems like a pretty common problem in camrys. My friend had to get his fixed one time and said it cost him like $900(pretty sure he got ripped off). Gonna do mine myself.
Dups1194 is offline
User Tag List
Linear Mode Linear Mode
« Back
