2001 Camry LE brake light off & on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2005, 10:19 AM   #1 (permalink)
View Jack1956's Photo Gallery
Hi,
Here's a good one: my brake light on my 2001 Camry LE(with 75K)comes on and goes off when I go around turns, usually in the morning. I don't necessarily have to be braking on the curves or turns(such as a rotary). I've checked my brake fluid and that's OK. I've pulled up and eased off on the emergency brake and that doesn't affect the light. Anyone know what could make it come on and off?
Jack1956 is offline   Reply With Quote
Old 10-18-2005, 01:05 PM   #2 (permalink)
Moving Forward
View Cyorke's Photo Gallery
it has to be the brake fluid level. DId you actually remove the cap and look inside the resevoir or did you jsut go by the indicator marks on the outside. How long has it been since you replaced the brakes on the car. I would guess with 75k miles you ahve done it atleast once and ready for the second in the near future.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 10-19-2005, 12:20 AM   #3 (permalink)
View ToyotaGuy50's Photo Gallery
Add a little brake fluid...it will go away.
There's a little float in your brake master reservoir that turns on the light when you brake
fluid is slighly low...
As your brakes wear they draw more brake fluid into the hydraulic system and the brake fluid level drops in the reservoir.
Toyota engineers designed it this way to coincide with brake wear.
In other words when that light goes on it's just about time to check your brakes for
wear.
ToyotaGuy50 is offline   Reply With Quote
Old 10-19-2005, 02:31 AM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
remember to take fluid back out when you change pads.
terrastrife is offline   Reply With Quote
