'95 Camry appears to be leaking power steering fluid, Suggestions? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2005, 02:41 PM   #1 (permalink)
View 95CamryLE's Photo Gallery
Unhappy '95 Camry appears to be leaking power steering fluid, Suggestions?
I have a '95 Camry LE 4-banger with 178,000 miles on it. It appears that my car is leaking power steering fluid. I've changed the fluid twice in the past few months. I first became alerted to the problem when my car starting whining when I would make a low-speed turn. Then I checked the power steering level to see it was low. So I changed it and the problem went away. Well a couple of months later, today, the sound was back and again the power steering level was low. Replaced the fluids and was on my merry way.
Well, this afternoon I was parked on some light-colored concrete and I saw a pool of power steering fluid (Dexron II/III I can't remember) on the ground. The reservoir is on the passenger side of the car, but the it was dripping down on the driver's side near one of the frame rails leading to the front suspension.
So am I looking at a fault power steering pump? Or is a line broken/leaking somewhere? How much do you think it would cost to replace a power steering pump + labor?
95CamryLE is offline   Reply With Quote
Old 10-28-2005, 03:11 PM   #2 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
tag - same problem, i ran out on monday
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 10-28-2005, 03:31 PM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The pump is also on the passenger side.
Check the hoses, steering rack, and the pump.
Theres a high pressure hose that leads from the pump to the steering rack. Sometimes it leaks.
"Skoolin' the unlearned!"
Old 10-28-2005, 03:36 PM   #4 (permalink)
Well, I'm in no way a "car repair guy," so I'm going to have to take it in
Old 10-28-2005, 08:09 PM   #5 (permalink)
Gameroom cash: $101605
View kenny1773's Photo Gallery
Lucas Power Steering stop leak
http://www.shopatmidway.com/showprod...iliateid=10050
This stopped the leak in my 95 camry COMPLETELY! Saved me a several hundred dollar repair and was recommended to me by my regular mechanis to try before he replaced the pump. I had to add in the entire bottle and then about half of another before the problem was gone. Ran it 10k after that and never had a problem.
kenny1773 is offline   Reply With Quote
Old 10-28-2005, 08:10 PM   #6 (permalink)
View Bill in SC's Photo Gallery
My '91 is leaking also. Get some Lucas power steering fluid and stop leak. It is guaranteed to stop any leak within two bottles, or your money back. It is pricy at $8 with the tax. I have gone through one bottle, and mine has slowed down a lot. Hopefully, one more bottle will do it. I think they can leak at the rack and pinion also. Good luck, and keep us posted on your outcome..
Bill in SC
Bill in SC is offline   Reply With Quote
Old 10-28-2005, 08:53 PM   #7 (permalink)
Thanks guys. You just saved me some much $$$ Can you get this stuff at Autozone or Advance?
Old 10-28-2005, 11:03 PM   #8 (permalink)
Triple A Whore
Edmond's Avatar
View Edmond's Photo Gallery
Probably. I used to have a leak as well and I used one of those that promised to stop leaks. And sure enough, it has stopped leaking.
Edmond.
Edmond is offline   Reply With Quote
Old 10-28-2005, 11:09 PM   #9 (permalink)
Lucas is different from most of the others, be sure you get the Lucas brand name. It is thicker.
Advance Auto sells it.
Old 10-28-2005, 11:25 PM   #10 (permalink)
View Gary_602Z's Photo Gallery
If it is leaking might as well get it fixed right. Aditives are just a temporary fix!
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 10-28-2005, 11:27 PM   #11 (permalink)
Gary
The car just needs to hold out until Jan. Then I'm getting a 2006 Mazda 3s Hatch Grand Touring
Old 10-29-2005, 05:01 PM   #12 (permalink)
Gary
It really depends. The Lucas PS fluid held mine for 10k miles and then I sold the car anyway and got a 2005 model. If 10k is temporary, then count me in
Old 10-20-2006, 12:15 AM   #13 (permalink)
View DesiToronto's Photo Gallery
Hey Guys....i know wrong forum..Ive got a Avalon 96....and recently found out badly leaking PS Fluid......Local dealer wants $1200 for reman Rack n Pinon and orignal toyota is $2600....so will try tomorow Lucas....
do you know any other good brands in market? I'm in canada
thanks
DesiToronto is offline   Reply With Quote
Old 10-23-2006, 08:11 PM   #14 (permalink)
97 Camry
View Davee's Photo Gallery
Canada
thanks
Lucas is available at CRAPPY TIRE. I used it in spite of no instructions regarding use in place of ATF. Used two bottles over two winters. It gets very thick in -40C cold & starts to leak again . But in general it works -- went all spring summer & fall without top up & I see it's down a little now
Davee is offline   Reply With Quote
Old 10-23-2006, 09:38 PM   #15 (permalink)
Canada
Hey Davee...thanks...I bought it from CT last friday...just to try.what the heckk...whats the worst that can happen..It actually worked!!! Hey just savedmyself some big bucks you know...I guess it fixed my worn out seals or something......
