Hydraulic cooling fan noise 93 Camry. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-05-2005, 03:52 PM   #1 (permalink)
View Diniman58's Photo Gallery
Hello All; I have a 93 XLE V-6. Has anyone run into the problem of the cooling fan (hydralically run off of the power steering pump) making excessive noise and outside of replacing the whole unit, is there anything that anyone has done to correct the problem. The noise increases with acceration and although he fan itself seems to be tight, I was wondering if it could be a bearing going out in the pump itself. Suggestions welcome...
Diniman58 is offline   Reply With Quote
Old 11-05-2005, 09:03 PM   #2 (permalink)
5spd V6 ClrTail's Avatar
View 5spd V6 ClrTail's Photo Gallery
This fan usually doesn't make noise unless theres a problem. U may be loosing water somewhere so the stepless/autovariable fan is working harder. Could be a hose leak or radiator prob. or maybe engine block problem. check all hoses first.
5spd V6 ClrTail is offline   Reply With Quote
